#91
Re: unfinished oem rarities list. Help me out you svx crazy people.
I could be wrong, but I believe these are a universal fit.
#92
I thought I would post it here. I finally found the Uber rare OEM Radiator with Aluminum tabs. I mentioned it quite a few times on the board, but no one seemed to know what I am talking about
I have seen it in person, checked its thickness and I can confirm that it is just the OEM rad + aluminum tabs intead of plastic. I don't know if it was OEM Subaru or just a modified from OEM. Here is the pic: And HERE is the link (just an SVX ad in Japan). BTW, Earl you might want to note the Vin.
Danny 1994 Silver SVX in hybernation, awaiting for the monsterous awakening (Lebanon) 1967 Mercedes-Benz 250SL Euro Specs, Hard/Softtop, White/Red. Under Complete Restoration 2013 Mercedes-Benz SL350 Euro Specs, White/Red. Mint... Another step into SL Collection. Last edited by SilverSpear; 05-05-2010 at 06:57 AM. |
#93
Go up.... lots of dust...
Guys need the part number of the headlights protectors. Trying something... Thx
#94
http://www.subaru-svx.net/forum/show...hlight=shields 14 years old and look as good as new. .
#95
My daughter had a '97 Outback with the same type of headlight protectors. They were fantastic. The headlights underneath were like new.
#96
OEM CD stacker holding bracket frame with SVX logo on the side, it fits at the base using the 2 holes near the side opening (where the antenna drain pipe fits) and then also connects to the actual antenna mounting point.
Note that my car has a removable door to get to CD stacker, other interior mats do not have this option - hence the add-on stacker holder that I am showing you.
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. Last edited by SURTEESS; 10-01-2017 at 10:33 PM. |
#97
Since someone has brought up the side indicator light mounted on the front wing, what about the non-USA front wing - without the indicator light hole, got to be rarer than the USA version?
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. Last edited by SURTEESS; 10-02-2017 at 04:43 PM. |
