Go Back   The Subaru SVX World Network > SVX Main Forums > Competition Motorsports
Old 03-12-2016, 06:45 PM
Gamesy's Avatar
Gamesy Gamesy is offline
SVX on dyno
Finally was able to get my svx on a dyno to see what stock numbers came up.
it was coming up 122awhp constantly.
Old 03-13-2016, 04:48 AM
Blacky Blacky is online now
Re: SVX on dyno
Sounds about right as there are huge losses in any AWD/4 wheel drive system.
My GMC truck was well over 300 engine horsepower and only had 210 HP at the rear wheels.
Old 03-21-2016, 07:54 AM
sicksubie's Avatar
Re: SVX on dyno
That does not sound right... 47% drivetrain loss? I have never seen that much loss on an SVX. When I benchmarked my SVX's (with the 4EAT) I was right around 150awhp.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 03-21-2016, 02:45 PM
SVX n00b
Re: SVX on dyno
What brand of dyno was this test performed on?
Same question to you sicksubie...
Old 03-21-2016, 03:28 PM
bishop bishop is offline
Re: SVX on dyno
When I dynoed my stock svx way back when with 170k miles it did 180whp 185wtq. Dynojet dyno btw.
Old 03-22-2016, 07:01 AM
sicksubie's Avatar
Re: SVX on dyno
Mustang dyno for me... Which makes sense as my numbers give me about a 35% drivetrain loss and Bishop using a Dynojet experienced a 22% drivetrain loss. The average difference between Dynojet and Mustang dynos is in the range of 12% with Mustangs reading lower.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 03-23-2016, 05:59 AM
Billsy Billsy is offline
Re: SVX on dyno
not sure how merican dynos compare, mine made 146 stock on a dyno dynamics rolling road.
https://www.youtube.com/watch?v=l5t0gUMbZ0M
Old 11-28-2016, 01:37 AM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
Re: SVX on dyno
Wow, that is almost a 50% loss!
What is your mileage? Still driving on the Autotragic?
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners
Old 11-28-2016, 04:37 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Re: SVX on dyno
So does that mean the gearbox is on the way out ???
Old 01-07-2017, 10:15 PM
GreenMarine's Avatar
GreenMarine GreenMarine is offline
From POST-***** to LURKER
Re: SVX on dyno
I've got video from my 5MT SVX on the dyno somewhere.... Let me see if I can find it... It was NEARLY 10 years ago so apoligies if I don't have it anymore... But I'll look
2020 Subaru Outback Touring - Wife's first Subaru
2005 Volvo V70R - 5-cylinder love! :Heart:
** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned
** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!!
** SOLD ** 1995 "Tree-Hugger Green" SVX L AWD(5 MT) --- "Gumby" 130K miles #399 in MY95, my original love...
Old 04-07-2017, 10:22 PM
Gamesy's Avatar
Re: SVX on dyno
i was 122awhp at 3800rpm
the svx is 230 crank at 5600 rpm
Old 07-12-2017, 10:44 AM
Nevin's Avatar
Nevin Nevin is offline
Re: SVX on dyno
Definitely sounds like a heartbreaker dyno for sure.
Dsport magazine did an issue a while back comparing different dynos with two cars to compare what the differences actually were.
Jesus is the remedy
2015 Expedition EL Ecoboost
Ebony Pearl '95 Subaru SVX LSi
Home of the Bontrager Works 22mm rear sway bar!!
Rate This Thread:
