Old 09-09-2015, 07:37 AM
bishop,
was your manual swap on your SVX?
Old 09-09-2015, 02:01 PM
bishop bishop is offline
Yes manual swap was on my svx, I really dont miss having abs, all it did was drop the pedal to the floor and try to kill me anyway.
Old 09-09-2015, 06:26 PM
Old 09-10-2015, 09:58 AM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
bishop,
Those headlight lens turned out really nice! Are you applying any clear/selaer to keep them that way, if so what? What method did you use to separate the lens from the housing?
Sam
Old 09-10-2015, 11:22 AM
Originally Posted by Svx95 View Post
bishop,
Sanded 80, 120, 220, 320, 600, 1200, 2000, 2500, 3000, cut & polish. Still building up layers of clear coat to polish back down to perfect.
Baked in the oven at 200 for about 15-20 minutes, to reassemble just do the same and press them back together. I didnt do it for long enough so the glue was still a bit stringy.
Old 09-10-2015, 03:43 PM
why take the lens off the headlight housing?
You are just polishing the fronts, no need to take them apart and risk leaks.
I took my headlights out and polished them while they remained intact.
baking 20 year old plastic in itself, makes the plastic all that more vulnerable/fragile...
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 09-10-2015, 08:56 PM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
Struts decided to kick the bucket. Here come coilovers.
Old 09-10-2015, 11:38 PM
Insides were full of cobwebs and dirt, i could shake it and hear everything rattling around, wanted to make sure they were clean inside and out.
Old 09-12-2015, 11:29 PM
Gamesy's Avatar
Gamesy Gamesy is offline
cleaner her up for the paul walker meet today
File Type: jpg 12002342_10206776519763690_1389042531478483913_o.jpg (449.6 KB, 736 views)
Old 09-13-2015, 08:48 AM
gwynethh's Avatar
gwynethh gwynethh is offline
Nice indeed.
"Peace is the flower of justice."
Old 09-14-2015, 09:11 AM
SVX_MY_BABY's Avatar
Blew a brake line before the right rear wheel.
Looking into having the new one re-routed to avoid dropping the transmission, subframe and gas tank.
Peter
Old 09-14-2015, 10:17 AM
about a month back I used some mild rubbing compound on the BRAT, which stripped off all the old wax. Well, it has been sitting out for the month with no protection to the paint. I had to re-do the hood just to get fly specs and sap that was stuck off. Then yesterday I finally got a day to get some wax on it. Not bad for paint that is now 30 years old.
glad I put the topper (Brat hat) on a few weeks ago, leaves are falling daily and last year I got stuck with a bed full of leaves and crud, that froze down.
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 09-15-2015, 11:59 PM
Didnt do anything to the car today but got my group buy ARP's in the mail.
Old 09-16-2015, 01:04 AM
Gamesy's Avatar
**** is that group buy for the arps done?
Old 09-16-2015, 01:56 AM
Pretty sure its done and over, a few people said they were ordering extras to sell to anyone that didnt make it. Head over to the thread and see who.
http://forums.nasioc.com/forums/show...0#post43657730
Display Modes
