Plans for the new SVX
As Old Tom said "And so it begins......."
Mortgage is paid off end of December, so will have a little spending money to put into the new car. Goal is a high performance daily driver that my wife can also drive, so keeping the automatic. Many of the mods below were validated on my Emerald Pearl, now in the possession of SuperCarnitas, that Young Tom was so instrumental in creating. Phase 1 * Rota Boost 17 x 8 flat black with red lip * Michelin Pilot Super Sport 245/40-17 Phase 2 * Brake redo - Stainless steel brake lines - Frozen rotors slotted rotors - Axxis Ulta ceramic pads front; Axxis Metal Masters rear (Ulta not available for rear) - ATE Super blue fluid - Speed bleeder valves - Red finished calipers Phase 3 * Phenolic spacers * AMR Engineering coil-overs with their “street” top-mounts; 350 lb/in fr, 250 lb/in rear (removable adjusting valve) * Urethane sway-bar bushings * $5, 15 minute rear subframe mod Phase 4 * Subiechip performance chip with Nissan z32 MAF and Nissan Skyline z32 injectors * Header back high flow exhaust system * Cold-air intake maybe with the custom Tomyx “snorkus”, if I can get someone to weld it up. Any suggestions?
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
Re: Plans for the new SVX
Any plans for 4.44 swap or will you be keeping the stock gearing?
Don't know. Haven't thought about it. Pretty big ticket item. Not sure about the benefits. What Subaru models have the 4.44?
4.44's are in the 97-99 (phase 1 transmissions, non-vtd, and correct me if I'm wrong on the years) 2.5 liter motors from the legacy, outback and forester. You do lose out on the high gearing for cruising (3000 rpm at 70 mph) but gain more low end grunt and reliability.
Dont forget an ECUTune valve body. I believe that Young Tom would weld one up for you if you asked him to. Tom
You should buy LANs performance transmission. It is still for sale on eBay.
I did the 4.44 conversion on my son's car and I definitely think it is well worth it, both in performance and durability. You do not notice much difference in cruising with the higher rpms. Throttle response is soooooo much better and off line power is very noticeable. AND, if anything, he gets better gas as the engine does not work as hard at cruising speeds. If you plan to keep the car for a lifetime like I am---used Legacy transmissions (4.44) are far more plentiful than SVX trans.
I might do the conversion on my runners if either has a trans problems. BUT, then again I have a parts car with only 2792 miles on the transmission AND engine.
SVXx2 92 SVX LS-L Silver 92 SVX LS-L Burgundy (structurally challenged with 2792 miles) 96 SVX LSi Red 92 SVX LS Pearl (Parts) 01 F150 4X4 Red (+6 with other members of the family) FREEDOM IS NOT FREE |
Is there actually any proven benefit to running the stage2, Z32 MAF, and 370cc injectors over stock with stage 1? From what I've read over the years stage 2 doesn't make any gains over stage 1 on stock motors.
1992 Dark Teal LS-L w/ 165k+ miles (traded ) Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs 2001 Black Toyota Sequoia (hauler/daily) 1992 Blue Toyota Cressida (drift car) 1992 Red Toyota MR2 (weekend/track day car) |
And was very satisfied with them. I have the Stage 2 on two of my SVXi. And am pleased with them as well. The supercharged car and The Racer. They both have headers and a very free flowing exhaust system. The Racer has all four of LAN's cams, (the big ones) and a 5 speed. SC car has 4.44s and porting. They both have phenolic spacers. If you go with the Stage 2 it gives you the ability to do more, like your phenolic spacers. If you go to a true cold air intake, cams, free flowing exhaust then we know that the Stage 2 upgrade has you covered. I will defer to LAN, as he has logged much more data. Tom
www.svxfiles.com The first SuperCharged SVX, the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway Fiberglass Hood thread My locker 4.44 Swap link Last edited by svxfiles; 06-09-2015 at 05:49 PM. |
The tuning on the ECUtune Stage1av1 and Stage2av1 were identical; however some testing was done by somebody else with your question in mind that indicated there might be some benefit to stepping up to the higher capacity air flow meter even on a stock car. I don't remember who it was or what the thread title was but he posted his information somewhere on these forums. He was logging the mass air flow meter readings and found the readings on the stock air flow meter got a little unstable at full load.
Nobody has ever done back to back testing of the same car on the same dyno on the same day to prove any performance difference since that would require changing fuel injectors and air flow meters on the dyno. I always recommended sticking with stage 1 since the total cost was much less. With the Subiechips chips the price is the same for the chip no matter which injectors or mass air meter but the cost of the injectors and air flow meter are still the major driving factor in the total cost. |
Do we have any options for live tuning yet? I'll be looking at the z32 maf and injectors soonish.
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. |
Nope, in fact community support (by way of purchase) for the ECUtuner software and interface were so poor that I haven't been able to invest the time to make an updated Subiechips version that runs on the newer versions of Windows.
I was going to add support for a pair of moates ostrich 2.0 emulators to the software to enable "live tuning" with real time updates but I'm not in a position to take that kind of time away from the things I do to make a living. |
"I was going to add support for a pair of moates ostrich 2.0 emulators"...............
You know, back in the day, we were high teck if we installed lighter springs and weights in our distributers, THAT STILL HAD POINTS! Sigh...
Yes, yes it did!
It's unfortunate that the Megasquirt planning never got sorted out. I've been working with one, and I think they'd offer a lot of flexibility in an application like this.
