#2476
I got up Saturday with the intention of getting my emissions inspected. When I started the car I of course got a check engine light (first time in years) and it was the for knock sensor (passenger side). I ordered a pair of replacements from Rock Auto since I didn't particularly like the brands Advance was selling. Now on to finding instructions on how to change them. I have done it on the 94 Legacy many times before but those were easier to get to apparently.
#2477
Crushed the little ferrite thingy in my ECU today. Then seafoamed it through the larger hose on top of the intake. No hesitation and smoother idle now. Plus it seems to have solved my high idle problem.
Now I might actually drive it a little again before I sell it
Glen SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery 2002 F550 74K SOLD - 2000 F450 215K 1987 BMW 535i 209K 1999 Yamaha SRX 700 |
#2479
As for replacement, follow what 92 SVX said. Remove the alternator and you'll have access from the front side. I was able to get the driver's side sensor by doing that, which is farther back and harder to get to, but I have small, skinny hands so I tend to have less issues reaching things in tight spaces than most people.
Jon 1997 SVX LSi Bordeaux Pearl 1995 SVX L AWD Polo Green - 277k miles 1986 Pontiac Fiero 3.4L Twin Dual Cam V6 |
#2480
#2481
In my experience and that of some other Members, Subaru is the only place to go for oil pressure sensors, two wire water temperature sensors and GASKETS AND SEALS!
Sorry for the rant. We also have to go to Subaru for ball joints. I have never had a problem with an aftermarket water pump, although YT does not use them due to his bad experiance with them, Mike, aka Longassname also does not use them. I go with Subaru thermostats and hoses. I USED to only go with Subaru radiator caps but the quality of the caps seems to have declined. For axles you have to measure the hub to make sure that it was made correctly or you end up with an inner axle seal misfit. (Outer SVX Axle hub diameter 59 MM is correct). But Miller brothers, Advance Auto Parts and Auto Zone seem to be fine, as long as you measure them. I hope that this helps. Tom
#2482
So I changed both the knock sensors after getting a code for just the bad passenger side. It was my first time and it took about 2.5hrs. I removed the alternator and it made it much easier but I still had to ask my wife to get to the drivers side after I loosened the bolt
Oh. Yeah, I thought I would show you what BOTH of the old knock senors looked like. (Can anyone tell if those are the original ones by any chance) I have never seen or heard of that happening before. Any ideas????
1994 SVX LSi JDM Tailbar and Grill, Clear Corners, 15min-mod, Nevin Blue RSB, G-FORCE SPORT COMP-2 Tires, Phenolic Spacers (Manifold & Throttle Body), SS Brake Lines, Maniac Electric Motors 160A Alternator 2008 Legacy 3.0R Last edited by theflystyle; 09-27-2014 at 09:09 PM. |
#2483
MELTED!?!?
The top of your block should never get over about 210°f!
#2484
Finally got the front brakes done. Seems like they have not been working for some time. We did rears 4 months ago ( suspected a frozen caliper, as the right rear got extremely hot) and then the fronts started chattering. Removed rotor and it was solid rust on the inside surface. See this image ::image.jpg. Wow they feel great now. Ceramic pads.
Wish I could post 2 photos.???? How? Why did this happen
When I was in school I sucked in sports. Then I found out I can buy trophies and now I am great at everything. Last edited by Conn SVX; 10-06-2014 at 04:26 PM. |
#2485
Put a my 6th set of tires. Pirelli P7 Cinturato All Season Plus tires on the 2010 Outback. After much research and reviews, these seem to be a really great tire in all areas. Read reviews on Tire Rack, 1010 Tires, etc.
The Michelin Premier AS scored a bit higher in some areas, but are a lot more expensive. Look how poor the ContiProContacts were. These were the new-generation Outback's OEM tire. Rated 22. Had 5 sets of them on for the past 250,000 miles. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 10-10-2014 at 09:00 PM. |
#2486
Big thanks to Denny "Pearlm30" for meeting me half way to pick these new BBS wheels up. Always nice to deal with him.
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel Last edited by michael; 10-05-2014 at 02:53 PM. |
#2487
Detailed my trunk. Vac it out, cleaned all the area around the trunk area. Waxed areas that can't be seen with trunk closed. ( all areas around the trunk support,and underside of lid. ) took it for a ride with new brake pads.. No vibration in the steering wheel. ( have always felt a slight tingle in the wheel. Found the reason for sure. ) stops are very smooth.
#2488
#2489
[SIGPIC][/SIGPIC]Kenyatta The farther backward you can look, the farther forward you are likely to see. -Winston Churchill My baby: 94 lsi My fast baby: 2001 Suzuki Marauder My new baby: 2010 Subaru Outback Last edited by trueblue; 10-06-2014 at 08:43 PM. |
#2490
The Pearlie turned 200K today!
ARMANDO 1992 SVX LS-L "Black Beauty" 292,500K (purchased April, 1997 w/65K) http://i1259.photobucket.com/albums/...psz1xmhtdo.jpg 1992 SVX LS-L "Blanca" 214,000K http://i1259.photobucket.com/albums/...pskv0odesa.jpg 2004 Mazda RX-8 http://i1259.photobucket.com/albums/...ps7vggfwfu.jpg 1974 Mazda RX-4 http://i1259.photobucket.com/albums/...psentjrygb.jpg |
