Old 06-24-2013, 08:41 PM
92 SVX 92 SVX is offline
Re: Just ordered my new AMR Engineering Coilovers
Originally Posted by steveherman View Post
There should be screws in the rear tray (yours must be missing)
Finished installing mine yesterday.
The only issue I ran into was that the front brakeline hose screw hole was too small.
Had to drill the hole bigger.
Impression of the drive... it is a little stiff.
I have it set to half way.
I will definitely go softer (Interior is still out of car)
I may even go with a lower spring rate.
But I love the feel of the stiffness... just not that stiff.
How low do you have the car sitting? Going up just a small amount may decrease some of the stiffness.
Old 06-24-2013, 09:22 PM
Steve and I did the install of these together. The coilovers are really well made, and obviously high quality from the moment you pick them up - made in the USA. These are definitely a better option than the koni/gcs, and I might actually pick up a set for myself one of these days if I've got some extra cash.
The front brakeline bracket on the coilover has a bigger captive nut than stock. I am not sure the thread size, but some extra random SVX bolts I had with 14mm heads fit perfectly (the stockers are 12mm heads). The hole in the mounting bracket of both Steve's stainless steel brake lines was too small for the 14mm bolt to fit through, so we had to drill them out. Some old rubber brake lines I had lying around which I assume are OEM would have had the same small problem. (This is an extremely tiny issue, just something I want to note so the next guy to install a set is prepared).
We set the firmness of the struts at a little firmer than halfway. I counted 8 clicks soft to hard, so we put them at 3 clicks from fully hard. I think I'd go a click or two softer, after the test drive, but that's something for Steve to play around with until he finds what he likes best. The springrates of his are 350 front and 250 rear (lb/in), which I think is great for a street car, but Steve found a little harsh. Steve's car already has had one of Nevin's RSBs, and with the coilovers, corners very flat. We made it really low, also - probably too low in the rear. Lower than mine in the rear. If you like the look of the back tires tucked into the wheel wells, then it's good. I think Steve will prefer the slightly-tilted-forward look, and raise up the rears some, and I kind of prefer that look too.
One more note - the coilovers shipped with the rears really short so they could fit into the box; make them around the height of the stock ones before you put them on the car, then adjust from there.
It is definitely possible and a good idea IMO to put a little hole in the panel above the adjusters for the rear struts. The adjuster that comes with them is basically a little allen key with a knurled thumbscrew attached, and the whole thing threads onto the top of the strut, so they don't get lost. Nifty little things, but one could use a regular allen key, for the extra length, to reach from a very small hole in the interior panel. A hole big enough to fit your fingers through to turn the little adjuster thingy would be on the big side. Either way, you'd want to plug or cover the hole somehow. (Here's an idea: a pair of stock front tweeter grills. They would be the right size, the exact right interior color, and then it would just look like there are more speakers back there.)
For comparison, the blue one is on 450/375 koni/gcs, and lowered more in the front than the rear, and the black one is stock:
Bigger pics here.
Old 06-25-2013, 12:31 AM
steveherman steveherman is offline
The pic of my car that icing posted is very low.
We actually raised it up more after that picture.
And tonite I lowered the stiffness all the way down.
I will drive it tomorrow and try to report back ttomorrow afternoon.
On a side note... if you guys ever get a chance to meet icing...
GREAT GUY.
We have worked on my car twice...
And both times that guy has been an extremely helpful and a nice guy.
Old 06-25-2013, 04:19 AM
GREAT GUY.
I couldn't agree more. Been down to meet him a few times never had the time to work on anything though.
How are the top mounts, front and rear? are they adjustable or no?
Old 06-25-2013, 06:57 AM
Thanks guys. Yea, there is never enough time for anything these days.
All the top mounts are fixed, and with the strut in the OEM location. But I don't think Steve's in need of that, and it would complicate getting an alignment.
Old 06-26-2013, 11:25 AM
subster subster is offline
Looking good fellas, I am curious to find out your experience on how long it took for delivery? I tried calling and emailing him and haven't heard anything back. I'm sure he's just busy.
Old 06-27-2013, 09:15 AM
Update: I heard back. Some scheduling problem occurred, but Andy is personally taking care of it. I have a feeling this upgrade will be as impressive of an improvement as the 5spd was for the car.
Old 07-01-2013, 04:55 AM
Andrew P.'s Avatar
Andrew P. Andrew P. is offline
The Ebony ones are faster.
I'm thinking it's time to order coilovers for mine.
Icingdeath what are those wheels off of?
92' Ebony. Magnaflow exhaust, tinted windows, STI wheels, 97' grille, Bontrager Works SB, ECUtune transaxle and TCU.
77' IHC Scout SSII
Old 07-01-2013, 06:26 AM
If you've got the money right now, do it. There's no knowing how long until something happens and they are no longer an option.
They are from one of these:
And I very much like them.
Old 07-01-2013, 06:40 PM
Ok... so I just picked up my car from enjuku racing.
They adjusted the coilovers.. aligned it... and replaced both rear wheel bearings.
I turned the knob to its softest position... much better.
Still a tad too stiff for me... but definitely not worth the expense to change the springs.
It is very very close to what I wanted.
Now the ride...
I have achilles sport atr summer tires on 18 inch rims.
I have nevins rear sway bar.
I have $10 mod 10 minute mod. (I think that is what it is called)
This thing handles as tight as my porsche did... maybe better!
Now I am very proud of the progress I have made with this car.
I invite anyone to drive it...
I bet you will be sold on the coilovers and the swaybar.
Paint next... scheduled for july 21... may do it sooner... impatient.
Old 07-01-2013, 08:50 PM
BackWoodsBob BackWoodsBob is offline
Wonder what the price would be for an 01 legacy, gonna have to contact this company! Bookmarked for future use!
Old 07-01-2013, 09:30 PM
EdWindows's Avatar
5spd + coilovers = win :D
Why don't you just buy some Stance coilovers or something similar? Unlike us SVX owners, the major coilover companies actually make direct fit coilovers for your car.
Old 07-02-2013, 04:45 AM
Andrew P.'s Avatar
I was asking about the wheels on the red one.
77' IHC Scout SSII
Old 07-02-2013, 10:42 AM
They are Stern st-4 Warp.
Aftermarket.
I got mine brand new for 500 shipped from California.
Old 07-02-2013, 01:33 PM
Not really, the 01 legacy was the first chassis to get the multi-link rear end so it wasn't very popular as it was the only chassis line until 07 to have it.
Display Modes
