Alternator Plug
After replacing my knock sensors I noticed the plug and wires on my alternator are toast. where can I get a new plug with a pig tail on it other then the dealer?
1997 Polo Green LSi #352 163,000 miles, let the rebuild begin! |
Re: Alternator Plug
"00 PM
svxcess Pristine Green Polo Machine Join Date: Feb 2001 Location: Westminster, MD Posts: 4,985 Re: Whan Can I get A New Alternator Plug -------------------------------------------------------------------------------- Quote: Originally Posted by Hocrest I think John "svxcess" found a source for these? If he doesn't reply here send him a PM. It used to be Northwest Regulator Supply. They only deal with manufacturers now. But you can buy them directly from their distributor Electric Motor Service in Logan, WV. Their phone number is 800- 697-6070 The part number is 050-012252 and they go for $9.53 each plus shipping with no minimum. I already ordered two more."
Re: Alternator Plug
Thank you, i will call them tomorrow
Re: Alternator Plug
Hijacking this thread
I de-pined my Alternator plug to repair It I dont know, if i got the wire switched so would someone tell me when looking down at ur alternator plug wire is the white wire on top or the bottom? thanks |
Re: Alternator Plug
With 2 you could simply open the4 hood on the other one and take a look! Keith |
Re: Alternator Plug
However the thick wire goes toward the passenger side of the SVX (in America) and the thin wire is more to the top.
Re: Alternator Plug
THIS SHOULD HELP. .
Re: Alternator Plug
that looks just like mine, same spot and everything where the exposed wire is.
i de-pined it too put some heat shrink tubing on it. looks like smaller wire is on top and the bigger white wire is on the bottom. then i have it wired wrong, hope I didn't fry the alt. Last edited by kjoyes; 04-13-2013 at 05:57 PM. |
Re: Alternator Plug
When you buy a new alternator plug, it comes with two 4" wires already attached. They are both the same size (about the same diameter as the smaller wire) and the colors are blue and brown.
Thread Tools | |
Display Modes | |
