Oxygen sensor and button illumination questions
Has anyone replaced the harness for the oxygen sensors? Is there one harness for all three or is there a separate one for the rear sesnor on the OBD2 cars?
Is the "CRUISE" button supposed to be back lit green like the other buttons? It is the only one that doesn't light up on my car. Well, that and the "D" light.
Re: Oxygen sensor and button illumination questions
See the complete list HERE Bulb number for illumination is 83426PA020. The complete list of bulbs can be found HERE .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 11-30-2012 at 01:42 PM. |
Great work John, thanks for your effort(s)!
Ray |
How hard is it to get to that green illumination bulb?
And, on a related subject, how hard is it to replace the bulb for "D" in between the gauges?
The hardest part is getting the gauge cluster out without breaking any tabs. Best to do it when it's warm out. I think I can walk you through it from memory if you need.
How about the illumination bulb for the buttons (cruise)?
See post #2. CRUISE Letters should illuminate green. AN orange LED on the switch should illuminate when activated.
Go HERE for the instrument panel and switch cluster removal instructions.
Go HERE for bulb illumination replacement instructions. Especially post 7. (brown ones are for illumination, blue ones are for the "on" indicators) You'll need to pop out the entire cluster. Use a small flat-bladed screwdriver on the outer edge (careful not to scratch the surround or dig into the switch) and pull with your index finger on the inner edge (closest the steering wheel). Should pop out easily. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 12-03-2012 at 09:19 PM. |
For the O2 sensor harness... why do you want to replace it? The rear has a separate harness that runs up the transmission to plug into the main harness on the right side. This is where the right O2 sensor connects also. Both of these connections run in through the right side harness. The left side O2 sensor connects into the harness on the left side with the transmission wires and the other small wires on the left side of the car. All of these run in and are part of the main harness that runs behind the dashboard.
So again, why so you want to replace the harness? And to answer the question directly, there is 1 harness for all 3 sensors, but it is the main harness for the car and it exits the cabin in different places |
Thanks for the links John.
As for why I am looking at the harness, I am getting a slow response code again for the rear sensor on my obd2 1996. I have tried Bosch and NGK sensors. My mechanic checked the exhaust for a leak and didn't find one. It is possible there is a vac or intake leak. I wanted to check out the harness first for bad continuity.
Try unplugging the rear sensor all together and see if a code comes up. I ran my 96 OBD2 for years with no rear sensor and never had an issue. Passes MASS emissions inspections and all with no problems, and had no check engine light for the rear ever.
