Thread Tools | Rate Thread | Display Modes |
#46
Re: East Coast-based 24 Hours of LeMONS/CHUMPCAR World Series SVX Race Team??
Dan,
Yep. My thinking is that we'll leave it as an automatic to accommodate the variety of drivers (skill level) we might have. I know that the amount of life left in it is questionable. I'd like to solicit the community for a "fresher" 4HEAT that we could outfit with LAN's valve body and TCU. We'd also run the largest dedicated cooler we can mount. Thoughts? Bill
#47
Great! Bill
#48
Still have your trailer and something to tow it with? I believe you will be our "ringer" driver. Bill
#49
Probably the first thing will be to know where you're located. The logistics of this budding team are starting to hurt my head already. Thanks. Bill
#50
Well said. My rough "mental plan" at this point is as follows: 1. Identify who is interested in participating 2. Identify the skill set each person brings and their level of commitment (i.e., how much time they'll actually be able to spend on this adventure) 3. Identify what will need to be done to the reX to make it durable/dependable for a 24 hour race (LeMONS) or less (CUMPCAR) and the cost associated with it. 4. Identify the availability and cost associated with the required safety equipment, as well as the labor/time required to get it all installed. 5. Develop a ROM cost estimate for single events based on an agreed up operational geographical area (i.e., we'll only compete at certain tracks) 6. Go after sponsors Thoughts? Bill
#51
Agreed. And this is where we'll need to make a team decision on how many events we actually want to participate in. Bill
#52
I still have a trailer, but there are limitations.
1. It is only 73-1/2" clear between the fenders. I don't know if the SVreX will fit. Even if it does, you will probably wnid up climbing out the window after you drive it on. 2. Although the trailer has a 6000 lb GVWR, my 6 cyl. Outback is only rated for 3000 lbs towing capacity. After all, my roadster weighed about 1000 lbs unoccupied. The trailer weights 850 lbs. How much does SVreX weigh? 3. The trailer is only 14' long. It is only 13'-1" from the back of the fuel jug rack to the end of the beavertail. Might make sense for me to lend the trailer to the cause if someone else has a more robust tow vehicle. My trailer has a standard 6 pin plug with electric brakes.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
#53
Does anyone know if Rufus (Mike Wirt) still checks into the Network since he doesn't have an SVX anymore?
Harry??? -Bill
#54
Call Him! Talk about a "ringer'!
#55
I think we are going to want a little bit more reasonable footwear on the beast. Looking a a minimum of 200 UTQG, the Dunlop Direzza Sport Z1 Star Spec compares very favorably on Tirerack, in both wet and dry performance, with the Yokohama ADVAN Neova AD08 and the Bridgestone Potenza RE-11, both of which are known as very good street/track compromises with wear ratings of 180. The Dunlop is also significantly less expensive going for $185 each in the 245/40-17 size.
#56
I thought I'd read somewhere recently that Hankook was bumping up the UTQG on their R-S3 tire from 140 to 200. One of my earlier posts in this thread called out the tire wear requirements for each series. The driving requirement is that the UTQG has to be 200 or higher. I've got to check if tires are included under the "safety" heading, as you will easily hit the $500 limit on tires alone. Bill
#57
Ouch. I can't imagine that tires count in the $500. The Hankook Ventus V12 evo K110 has a 280 wear rating, and it is only $114 at that size, but the ratings are really bad. What is the size of the existing wheels on the reX?
#58
Bill
#59
Are the 17" Mustang rims the right bolt pattern and offset? What width are they? With 295's, I would think you would want a minimum of a 9" width, and maybe 10". Otherwise, you get weird bowing of the tread, which might not hold up very well over 24 hours.
I have been very pleased with how my 245-40/17's worked on my 17x8 rims. No rubbing, reasonable wear pattern and great road holding. Also, the speedo is pretty accurate as teh diameter is almost the same as the stock 225-50/16's.
#60
Tires will fall under "safety".
