Old 04-01-2012, 09:04 PM
ian2120 ian2120 is offline
In the midst of some electrical hiccups. Replaced the bad alternator two weeks ago, and had a short fixed after my 94 LSi didn't start.
Friday, I had the Steering, Battery, Brake Light(!), and ABS warning lights on, and just got to the mechanics as the power steering went on me and the car died.
Saturday morning, the battery was replaced. The warning lights remained on until I put the car in power mode, and then then they shut off.
Today, starting the car after work, the same lights come back on, and the stereo died and wipers slowed as I pulled into my driveway.
Tomorrow? Driving to school with jumper cables, hoping to get there, and to the shop afterwards without a problem. Any thoughts as to what could be the issue?
Old 04-01-2012, 09:17 PM
You need a better quality alternator rebuild...
or, it could be grounds. Where did you get the alt from?
Old 04-01-2012, 09:20 PM
North Ursalia North Ursalia is offline
Hi Mr. Penguin!
Originally Posted by dannmarr View Post
I got tired of messing with the blue wire to access the engine codes. So I installed a pull switch so I can easily check the codes without removing the kick panel.
Great minds think alike- I just finished this up last night:
top switch only does the memory read, top and bottom buttons will clear the code.
Old 04-01-2012, 09:40 PM
dbarnblatt's Avatar
Great idea! Good work.
Old 04-01-2012, 09:42 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
I was also thinking about 2 switches, but I did a quick install with a switch I had laying around. WOW! Nice clean job!
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 04-01-2012, 09:53 PM
Green1995SVX's Avatar
I forgot to post, but a couple of weeks ago, Nate and I successfully swapped my SVX to 5 speed. It came out great!
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 04-01-2012, 09:56 PM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
ALl you did was run one wire from the switch, to that spot?
Old 04-01-2012, 10:11 PM
Wire the blue wire to one contact and a wire into the pin for the other contact for the switct. Connects the circuit so you can check codes.
Old 04-01-2012, 10:41 PM
Chuckls's Avatar
Designated Asshole
Ah okay..Might want to do this with you and Subix if we get the chance when I come to Indy.
Old 04-02-2012, 07:04 AM
Obewon Obewon is offline
Took my '92 out for a 90-minute drive after it had been sitting for a week.
Nice day, nice cruise, hit 100 mph twice on some long open stretches.
Damn ! That is one nice car, even when 20 yrs old.
92 SVX, Ebony Mica 186,000 kms
92 Mercedes Benz 300CE, Arctic White 187,000 kms
Old 04-02-2012, 08:11 AM
Check your crank pulley.....
Old 04-02-2012, 08:21 AM
Chuckls's Avatar
Designated Asshole
Originally Posted by huck369 View Post
Check your prank pulley.....
It's not april fools anymore!
Old 04-02-2012, 09:31 AM
Nice. Welcome to the club.
What kind of 5-speed did you use?
Old 04-02-2012, 09:52 AM
fzftw's Avatar
fzftw fzftw is offline
Just dip a toe!
Brilliant! I'm going to do that too now.
-Brian
Current fleet:
89 D21 2wd
91 XT6
93 D21 4wd
95 SVX LSi
02 Windstar Sport
03 CL500
03 Avalanche NF
07 RDX
08 Outback
10 Outback
10 Murano
12 Accent
15 STi
Old 04-02-2012, 11:05 AM
No April fools, sounds like his crank pulley is separating....
