Old 05-02-2011, 01:28 PM
kwren's Avatar
kwren kwren is offline
R1 Concepts Premium Cross-Drilled & Slotted Brake Rotors
anyone using these please review the results? also how about their Posi Quiet Extended Wear Brake Pads...
Thanks,
Keith
Old 05-03-2011, 09:17 PM
kwren's Avatar
Re: R1 Concepts Premium Cross-Drilled & Slotted Brake Rotors
Guess no one has tried them... They are pretty pricey!
Maybe someone has a good suggestion. Some source that would be better than the original Subaru that have a tendency to warp a bit?
Keith
Old 05-03-2011, 09:45 PM
They are pretty good. I'm using the premium ones in the front and the regular ones in the rear. EMC Redstuff brake pads and SS brakelines. It all works very well together. I haven't gotten it to the track as yet though.
Old 05-03-2011, 10:49 PM
kwren's Avatar
Thanks for responding! Do the brake pads come from the same source?
Thanks,
Keith
Old 05-04-2011, 12:31 AM
Nope. Search EBC's website for the part number and then the part number for online stores that sell them. I bought mine from autoanything, but they took forever to ship them, I wouldn't recommend them at all.
The pads that R1 concepts sells might actually be good though. But the redstuff pads kick ass for sure.
Old 05-04-2011, 01:18 PM
92 SVX 92 SVX is offline
I am using R1's house branded ceramics front and back, along with there Stainless lines and rotors I think they are working well together.
Old 05-04-2011, 04:42 PM
Mr. Claret's Avatar
Mr. Claret Mr. Claret is offline
I concur that R1 premium rotors and EBC Redstuff are a great combination and are fairly low dust pads. If you don't drive fairly hard, I am not sure I would recommend the pads as they like to be USED! Mainly if you are light on them most of the time, they will glaze over and not act appropriately. Using them somewhat excessively will expose the fibers on the surface of the pad and operate as designed. The drilled/slotted rotor helps keep the pad conditioned and the surface flat in my experience.
Hope that helps
- Sonny
[1992 LSl, Claret 160k] / [1992 LSl, Dark Teal #378 172k] / [1992 LSl, Claret 150k] / [1992 LSl, Liquid Silver donor] / [1992 LSl, Liquid Silver 4.44] / [1997 LSi, Polo green #089, 150k]
1992 Chevrolet Lumina Z34, white 35k miles
1992 Chevrolet Lumina Euro, charcoal grey >200k (first car)
1992 Chevrolet Lumina Euro, charcoal grey >200K (for sale)
1986 Honda VF500F Interceptor
1994 GMC Jimmy S-15
Old 05-05-2011, 01:35 AM
kwren's Avatar
It does!
Thanks...
Keith
Old 05-05-2011, 08:13 AM
The stainless brake lines are one of the best ways to improve your brakes even if you don't do anything else. If you start to upgrade rotors and pads, it gets better than that!
Old 05-05-2011, 08:44 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Yeah ill back that 100%. Turns the spongey mushy jello brakes into real boy brakes.
Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1˝" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint.
Old 05-05-2011, 10:51 AM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
how easy is the lines to replace. any how to's?
Old 05-05-2011, 11:08 AM
They aren't that hard, but honestly I'd have a shop do it just because it's not that expensive and brakes are kinda super important. Plus bleeding brakes is a pain and many shops have vacuum pumps that make it easier.
Old 05-05-2011, 11:09 AM
kwren's Avatar
so easy that reading "how to's" would take up too much of your putting it up on jack stands, unscrewing the ends to take the old lines off the new lines on, one at a time, being careful to get the old flat copper washer seals off and out of the way and the new flat copper washer seals correctly placed on each of the new lines as you bolt the end on, and your bleeding the system time!
All that considered, a "how to's" might be a waste of time.
Keith
Old 05-05-2011, 11:12 AM
kwren's Avatar
You can also get one that works off your air compressor that makes it easier still and do it yourself...
Keith
Old 05-05-2011, 12:16 PM
Keith
Very few people have compressors at home. And odds are if you have your own compressor, you're not the type to need help changing brake lines...
Display Modes
