Thread Tools | Display Modes |
Transmission fluid drain, refill and "how the hell do I read the dipstick!"
After diagnosing my valve cover gasket leak, the mechanic did my second drain and refill of the ATF along with changing out the internal filter. The last time they drained it, only about 4 quarts came out. I brought about 5.5 quarts with me and he said it was still reading low. Clearly more drained out this time. I came home and checked the level again after a 20 minute drive and it did seem low. But, damn, this is hard to read! It looked like it was just above the cold "L" mark. The little hole was filled but it was hard to say how much higher the fluid really was. I added about another half quart but had a hell of a time reading the levels. Clearly it takes a very long time for the fill tube to drain. But I don't want to keep the car idling forever. Do you guys have a procedure to get a good accurate reading on the dipstick? It always seems like there are dry sections all over the stick and wet sections high up the stick.
And does anyone have a feel for how many quarts are needed to get you from the cold "L" to the hot "L" (same as the cold "F"?) and from the hot "L" to the hot "F"?
Re: Transmission fluid drain, refill and "how the hell do I read the dipstick!"
Keith ![]() |
you could sand the end of the atf dipstick down make it ruff, and paint it a flat black. nothing too smooth. then the atf will stick to it and measure alot easier.
1985 Brat GL 138k 91 CRX Si 40k 91 CRX Si 155k 97 SVX Lsi 70k 2003 s2000 91 RT4WD 166K |
I choose to ignore the atf spattered 2 inches above all the markings on the dipstick and go solely with which hole is filled. Dunking the stick in atf is going to fill the holes. Dragging it against atf splashed up the tube can account for the rest of the mess but it won't consistently fill the holes. Right or wrong, thats my method.
You will find that if your ATF level is too low, your torque converter will not lock up at highway speeds, or may lock and unlock randomly.
From personal experience on my 96 Polo ,
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
This morning I checked it cold again, after cycling through the gears of course and keeping the engine running. The level looked to actually be below the bottom circle?! None of the circles were filled but the fluid looked to be just below the bottom one. So I took the car for a 10+ mile drive with a mix of city and highway driving. Immediately after getting back I checked the stick and the first check showed two filled circles but the top one wasn't filled. My son's opinion was that the fluid looked to be about mid-way between the top two circles. I checked it again and the top circle was filled!!! But, again, the wetting is inconsistent. I even took a wire brush to the stick to rough it up but the wetting still isn't complete and even on the stick. It almost looks like the fluid is splashing up into the fill tube when driving and some of the fluid on the walls of the tube is getting on the stick when I check it. I suppose it is possible that I am just barely at the top circle and so it fills sometimes but not always. Comments?
Toney, are you also having problems with your transmission not functioning correctly?
Keith ![]() |
From the Factory Service Manual Seems like on the HOT side the dipstick, the bottom and center holes should be filled filled and the top one is open. On the COLD side of the dipstick, only the bottom hole should be filled. .
Also, I don't notice any symptoms of the fluid being underfilled. There is no feeling of "slipping" or harsh shifts. The level is probably fine. I just wish I could tell for sure by looking at the stick!!!
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 01-02-2011 at 11:58 AM. |
I always look at the back side of the ATF dipstick.
The side that faces the firewall. And usually it takes three times to get an accurate reading.
www.svxfiles.com The first SuperCharged SVX, ![]() the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway ![]() Fiberglass Hood thread My locker 4.44 Swap link |
The way I see it is you have good news and bad news, Tony...
The bad news is not nearly as bad as the good news is good. The good news that you have no problems with your transmission.. That surpasses, by far, the bad news that you are unable to check fluid level in a transmission. My comment would be... perhaps for "piece of mind" going back to a Subaru dealer and asking them to recheck your transmission fluid level. My thought would be that they would be willing to do this at no charge. ![]() Granted, there would be some expense for fuel to drive there, but the resulting piece of mine would far overshadow that minimal expense! That would be my best recommendation. Have a great and prosperous new year! Keith ![]() |
Do you have a feel for how much the level should rise from cold to hot?
Hi Tony,
I have used the partial drain and fill PM method for years on my 87 Jag XJ6 and now on two of our SVXi and both Outbacks. I ran into the hard to read dipstick phenomena. I suggest using a graduated paint bucket to catch the drain ATF, then just add back the same amount. It has worked well for me, after the ATF discolors a bit, it is much easier to read...
![]() 1997 Ebony #308 113k "The Black Diva"SOLD ![]() 1992 Black over Liquid Silver 152k SOLD ![]() 1992 Ebony 251k 444 SOLD ![]() 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
Thread Tools | |
Display Modes | |
