fixed door glass replacement
how difficult is it to replace the door glass? i have yet to track one down or figure out what color the fixed driver glass is, but i want to see how difficult it is to replace. i did a search with no luck. thanks for any info!
Re: fixed door glass replacement
Raul, I've heard that it is not possible to remove the fixed glass while saving the seals and whatnot. However, with broken glass and putting a replacement pane in place, it may be possible. If it's not, you may end up needing a door.
![]() Also, yours is bronze glass I think I remember from seeing your pics but don't quote me on that. |
awww... thats pretty unfortunate. anyone done this before?
I have a spare drivers door in San Antonio, tx........
-Steven 1992 SVX Purple and Black 5 speed swap SOLD *1993 SVX Silver and Black *1994 SVX L Barcelona Red FWD |
mines a 94 lsi in barcelona red. not a spec of rust
Raul, if I come across a red door on my trips, I'll give you a call with the info. I do have doors, one happens to be a claret but at least it has the bronze tint you would need and your car does kinda need paint anyway
![]() If nothing else comes around. It's a rust free door from VA that I got from Somethingelse on one of my other trips to originally use for the Laguna. Otherwise, if it's confirmed glass cannot easily be put in, post in the wanted forum for a barcelona red door with bronze tint. If its somewhere that I can get it, I have no problem picking it up for ya. ![]() |
im tempted to pull the shattered glass out and see how it looks, but i dont want to do that if im not sure i can get the new glass in. what a pita...
and your not kidding about the paint! lol. when i washed the car, the paint peeled clear off of the sideskirts when i hit it with a hose! |
Wow, I can believe it...
Yeah, wait for a response from someone who might know. Or if I get ambitous I'll break the fixed glass on teh laguna doors i pulled off and test fit the glass i do have to see if it can be done.. |
There were two guys actually told me that the upper fixed windows can be replaced.
They are auto body men. So I trust them. Because I thought I found a black door with brown tint. Then I found a part car with a similar color door with same color tint. That makes it easier.
I work for an auto glass company, and this can be done, but you will need the right adhesive and a steady hand to cut down the old glass/glue.
If your upper door glass is shattered, the replacement can be done without power tools. You will need to shave down the adhesive and remove all debris from the area. You can use an automotive grade urethane adhesive such as Sika 220/SikaCool/ or a Dow equivalent to properly install the glass.
1991 SVX L JDM 1992 SVX LS-L USDM 82 911SC Targa, 89 325i Convertible, 96 XJR, 08 LR3 SE |
My buddy that has a auto glass shop, has done one of those for me before, he cursed a bit while doing it, but got it done, looked like new.
Huck Subaru Ambassador 92 SVX LS-Tour Magnaflow Exhaust, 5-Spd-AWD ![]() 88 XT6 AWD 5-Speed "Bride of FrankenWedge" 15 Impreza Premium Sedan 15 Crosstrek XV 5-Speed My 5-Speed "How-To" Write-up 1976 Pontiac Firebird Formula Current Count of Subaru's Owned.... "70" |
thanks guys for all the info! ill check my funds after rent, and see if i can afford to pick up the glass!
You ever get the glass replaced?
Thread Tools | |
Display Modes | |
