air lock
Drained the system then refilled with anti-freeze and now can't get the air lock out. Any suggestions?
Re: air lock
Have you run it yet? Take the rad cap off, fill the rad, start engine, watch coolant level and fill as necessary. Continue until the fans come on. Top up your overflow tank, put the rad cap back on and go for a drive. Let the engine cool and check the coolant level in the rad again.
Re: air lock
Yeah warmed up all the way with the cap off and started pushing alot back out the top
Re: air lock
Just run the car normally and keep refilling the reservoir until the coolant no longer disappears. We dont have a bleeder screw, you can also fill thru the upper hose into the engine initially, but to get all the air out you just drive normally and keep the res full.
Re: air lock
Even if its still not blowing any heat?!
Re: air lock
Not blowing heat eh? Did you fill from the upper hose into the engine?
Re: air lock
Some say you need to elevate the front end and run/fill it to burp the Subaru H6's.
Christian- 96 SVX Lsi #821, Bordeaux Pearl, 4.44 98 Legacy Trans, Trans Resistor Mod, Dakota Digital Trans Temp Gauge on A-Pillar Pod (awesome), B&M Trans Cooler in Driver's Wheel Well, External Spin-on Trans Filter, Synthetic Fluids in Trans and Diffs, 17x7.5 Primax 695 Rims, Alcyone Rear Panel, Svxfiles' 5000 k HIDs, Clear Headlights, "BOXER6" License Plate, Hard Wired Radar Detector, 94 Power Up Window Switch, Motor Resealed, new Coil Packs, new NGK Iridium Plugs, PVC Valve, Drilled and Slotted Rotors, Gloss Black Calipers and Rotors, EBC Greenstuff Pads, SS Brake Lines, Superb TomsSVX Cat Back Exhaust... SS Resonator, Flowmaster 80 Muffler, Magnaflow Quad SS Tips, Poly Swaybar Bushings, Endlink Mod, Rear Subframe Bushing Mod. Feels great and sounds even better. Thanks to AWD, LLC. 2003 Outback llb H6 3.0 Titanium Pearl- "BOXERR" Mostly Stock 1995 Bmw 325i Conv. Calypso Red- "RBOXER" Modest Mods 2004 Sea Doo Sportster 4-tec 15' Jet Boat, 1494cc, 1454#, 155 HP= <10#/HP Stock |
Thread Tools | |
Display Modes | |
