I did some talking with Mychailo about this idea, comparing the basic dimensions of the SVX and Impreza/STI struts. The fronts are roughly the same length, but the rear STI struts are 1.5-2" longer than ours. That in itself is not a problem, a suitable drop spring setup(or adjustable coilovers) would bring the ride height back to normal. The problem is that the STI has as much travel as we do in the rear. So to drop the rear to normal ride height you would use up 1.5" of suspension travel, giving you less than the SVX has. So, my opinion on the swap as of now:
The STI suspension CAN be used, with modifications. 1. Both front and rear SVX knuckles will have to be thinned somehow to fit into the strut mounting flange. Either by machining or grinding. Or you can pry the flange open to fit onto the SVX knuckle. 2. SVX top mounts will have to be used, or the shock towers in the SVX body will have to be drilled and cut to accomodate the different bolt patterns. 3. A bracket will have to be welded to the front control arms, allowing an aftermarket swaybar endlink to attach to the control arm rather than the strut. A rear '05 Outback endlink works perfectly. 4. The rear STI suspension will have to be compressed. This will sacrifice roughly 1.5" of rear suspension travel. To prevent the shocks from bottoming out a higher spring rate will have to be used. This will obviously have an effect on the handling characteristics. Cost for this way of doing it: STI suspension+machining cost for knuckles+SVX top mounts+2005 Outback endlinks+bracket+welding bracket to control arm. The big ticket option: Use a custom machined balljoint adapter to use the STI front knuckle. This allows you to use STI Brembos, and any other BBK for the STI. Cost for this option: All of option A (minus machining knuckle) + balljoint adapter+STI knuckle and associated parts+Brembos
Re: STI Suspension Swap Project
So.... I bought a set of Stance GR+ coilovers today. They are 2002-07 WRX fitment. It'll be a little bit before they're shipped up, but I'm excited! Every day I see my classmates' 240SX and Prelude, both of which are lowered, and I'm getting real tired of the high front end of the SVX.
*manic laughter*
Gots me some stuff!!!!
Get those things installed now!!
And document everything you have to do to make them work (assuming it's changed from your speculations and measurements prior). |
I most certainly will.
pictures of adapted front end??? plans for the adapter???
Why don't you just cut out the SVX body mount where the struts bolt to the body, and weld in your own piece that is the same fitment as the wrx top mount?
Jesus is the remedy 2015 Expedition EL Ecoboost Ebony Pearl '95 Subaru SVX LSi Home of the Bontrager Works 22mm rear sway bar!! |
Nothing installed yet, I've got to find some free time from school to get this done.
Maybe a dumb question but why not swap SVX camber plates onto the coilovers?
#28
It's an option (as long as they bolt up), but it's just more money.
To give you an idea of just how minor the hole drilling will be:
#29
I would be concerned with how close those holes are to each other...
#30
^ what he said, honestly, if possible, i would re-drill all 3 holes to space them away from the existing as much as possible.
94 Acura Integra GSR 97 Legacy Brighton - EG33 Swap still in progress 03 Silverado 2500 - Duramax |
