Re: help,turn key to start,no sound
+1 for attempting to start it in neutral, if for no other reason than simple diagnostics.
Why did they add a relay to the US model? Is there some requirement here in the US that would obligate an import to be equipped with one? EDIT: In my personal experiences (have replaced many faulty starters, and a couple of good ones) there should be a clicking sound, either single or repeated when you attempt to crank the engine over. If there is no clicking, then the starter is simply not being engaged. Most likely caused by an electrical issue. Since you hear no clicking, I am going to advise your starter is fine.
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted Last edited by Cam; 08-18-2010 at 06:42 PM. |
Of course, the trying to start in "N" is not exactly testing the switch. Keith ![]() |
![]() Very good reason to START with the easiest thing to test. If it doesnt work, then we know its something else, since those tests aren't as easy. Remember I got 5 forum pesos on this, and I always pay up. |
A friend of mine owns a Ford Expedition and sometimes he has to go back and forth between park and neutral several times before the car will start. I was going to try and adjust his neutral safety switch. Should I be chasing a different problem or is it still logical that the NSS is not adjusted properly although it sometimes does not start in neutral?
The low current flow through that switch and the construction of it makes me think there is little chance that it is a problem. I don't remember that ever being the problem here... If you have a wiring diagram you can test the circuit. If you need one, you possible can download one here on this site. Just say what you need. ![]() Good luck Keith |
![]() I have already decided either the whole world is crazy or just me... Back to bed! ![]() Maybe it will get clearer tomorrow ![]() Keith ![]() |
after i came down from the snow mountain,
on the 18-19aug,idrove 400km back to auckland,stop in hamilton for one night, both 2 days,its started fine,so I have not use the start-in-neutral yet. still looking 4 the real problem? I had a feeling that it get worse when up on the snow of -1degree, becos that one time that i could not start at the snow parking,it took me 6-8 times to start,(its the worst,other times it took 2-3 times to start)n before it could start again,I think i try to shaken the battery connection,and the gear shift too...... so ,may be starting in neutral will work afterall. I will try the next time it happened,but dont know when, its the uncertainty that make me nerveous.
1992 SVX whitepearl 129,000km 2005 MAZDA3 red 38,000km 2001 HYUNDAI XG V6.3000 2003 TOYOTA PREVIA |
as i said the last 2 days it starts well,so hav not got a chance yet. I will report back. I am certain when i turn further to start,not a click,it just silent.
I hope too that my starter is ok.(cos its very dear.) and since I hear no sound at all,not a click, so if it should be an electrical issue,and if i can start my car by shifting to N then,I might as well not fix it,and shift to N everytime it happens, as i only use my car about 1500km each year. If i dont fix that,is there any problem in longer term?
I didn't consider it confrontational, just a bit misleading and wrong. CLEARLY, what I am about to say does NOT apply to this current problem but does apply to every 92 USDM model that I have looked at. The FACTORY relay USES ONLY 4 Pins----TRUE, but it IS a 5 PIN receptacle PLUG for the relay with only 4 wires going to it and a blank area for the 5th pin to fit. ALSO, the 5 pin BOSCH relays used in both the factory and NORMALLY the bypass have TWO (2) 87 Pins (87 and 87a) which are obviously the same so only one is used. It is actually just a 4 pin relay configured with 5 pins for optional mounting plug situations. Again,ONLY one of the 87 pins is used. I can provide a wiring harness pic of the 4 wire, 5 receptacle plug if you are still in doubt. ![]() Not being confrontational--just accurate. ![]() Lee
SVXx2 92 SVX LS-L Silver 92 SVX LS-L Burgundy (structurally challenged with 2792 miles) 96 SVX LSi Red 92 SVX L Pearl (Body-rust free) 20 F150 4X4 King Ranch FREEDOM IS NOT FREE Last edited by lhopp77; 08-19-2010 at 09:42 AM. |
#28
The reason for only 4 wires would be that that particular 5 terminal relays function requires the use of only 4 terminals and is not even relevant. The extra terminal is the way of running the start circuit through the normally closed relay points to complete the desired starting circuit path, of course that has to be one of the only 4 terminals that are used. Naturally, as you know, the Bosch 4 terminal relay will not work in that situation. Keith ![]() |
#29
Have you find the Problem.
I have the same on mine and its the Negative term on my batteriwiring is verry old so i have to replace this. But its help to spray electronick cleaner on the wire. This problem start afer it have been in a ''open'' garage in the winter. So i will also chek the negative wiring term on the batteri. ![]()
Alexander (Norway) My subarus: 1992 Svx LSI 5-MT(3.54) 1998 Legacy BG 2.5L GX |
