OEM Conrods worth it?
Okay so my new build will be a bit on the cheap side. I'd LIKE to do full internals but I also know I'm really going budget where I can. I want to do the pistons to OEM spec or maybe even LAN's 11:1. IDK really, but I have low goals and this will get either rebuilt again in the future or I'll build another one to replace it. I just want to know how competent are the OEM rods? Just a PnP and a valvetrain rebuild for the most part with a light hone to the cylinder walls to make sure they aren't scored and slap it all together. I just want to know if I'm staying way below or at 300BHP will i run into issues with the OEM conrods? I'm not looking to make a monster and likely won't even see 275BHP but just in the off chance I wanted to know.
Discuss....
94 Bordeux Pearl LSi (Jun 2009) 109k Plate:GADDIS What they call it a vanity-plate. Shouldn't I be obligated to be vane with it? Rota Tarmac 3's 18x8" on 245/40/18 Dunlop SP Sport 600's, Perrin light weight crank pulley, PRW radiator, custom coilovers(not GC's), 9006 HID 4300k 50W low beams, DIY garage door lip, and SVXfiles brake kit. Fixxed exhaust so no more sweet sound. 97 White/Black trim Impreza Outback Sport (March 13/08) 150K-180K(sensor broken)Good news is EZ30R and 05' 6speed full powertrain swap is in motion!: Will be doing more work as I can. Gonna be run by a Hydra so yeah fun to be had. [SIGPIC][/SIGPIC] -Gaddis |
Re: OEM Conrods worth it?
You may hear a lot of opinions of with and against right now. But I tell you this...
Never gamble with the engine's internals. What if one breaks? What would happen to your engine? It is up to you.
stock rods with ARP fasteners will be good
Tom |
Jack Laverty kicked out a stock 140,000+ mile rod only because he:
A) Was making 318 whp B) Was revving to 8200 rpms C) Lost oil pressure due to 1.5+ G's of lateral acceleration which starved the pump. A street car on street tires driving on the street will never see this kind of cornering force. For just about anything else I think you'd be fine. |
'07 Outback (Legacy) Pearl White > 3.0R Premium, stock (50,000km, Wifes daily driver. Owned from new) Not For Sale '92 SVX Black on Pearl White > 6spd, DCCD on the way. (260,000km, My daily driver, 2 previous owners) Not For Sale '93 SVX Black on Charcoal > Aftermarket rims.(250,000 km, Dad's daily driver, unknown owners) Not For Sale '93 SVX Black on Burgundy > Completely stock, under preservation, treated like a princess. (55,000km, 1 previous owner) Not For Sale '92 SVX Black on Burgundy > Completely stock, under preservation, treated like a princess. (144,000km, 2 previous owners) Not For Sale Wife, Red Hot when riled > Treated like a princess. Minister For Finance, Domestic Affairs and Diplomatic Relations. Definitely Not For Sale My Wanted List: http://www.subaru-svx.net/forum/show...178#post632178 |
Doh... I knew I forgot something.. |
Indeed... Now to figure out HOW ON EARTH TO JUSTIFY COST ON PISTONS! What's the stock ratio anyways? Are LAN's 9.3's=OEM? I want a little more but I don't think it's worth the 11:1's... Oh well goals aren't high anyways. More like making a fresh motor that HAPPENS to put out a little more. Tom and Bob I think I'll be PMing you guys with a few questions as I wish to pick yo brains!
stock CR is 10:1 if I remember correctly...
Are you doing anything for engine management? With the stock MAF maxing out in the 250 HP range there isn't a whole lot of room for improvement without going to a different support system. Although most of our engines are old and tired, so bringing them back to even stock power levels is an improvement.
Another alternative is going with STi rods and ARP bolts. Little more margin and you should be able to pick up some from over at NASIOC when they upgrade to aftermarket rods.
-Bill
Good point but I'll save that for the next step of the build. Hell pistons might even be put on the second part of the build. LAN's pistons are PRICEY! And what's with the 9.3:1 of stock is 10:1? How much change on the low and high end is that 0.7 in compression gonna change things? If it won't hurt top end(which really isn't my worry as much as low end) and I can level out my tune on the MS2 to really boost up my fuel consumption efficency then HELL YEAH!
Bump for answer about the piston specs?
stock pistons will be more than enough for what you are looking for.... Yes they are 10:1. I see no reason to use any other pistons with an engine you are basically keeping stock
Tom |
Thread Tools | |
Display Modes | |
