transmission question....
dose a legacy have the same transmission as an svx and if so what do i have to do to swap it into an svx.
I has teh FWD LS-L |
Re: transmission question....
It's different but an easy plug and play swap. You will need the rear differential to go with it because the gear ratio is different. Do a search there's tons of info on this.
what years work ?
I believe '96 to '99 are the ones use the search feature.
How to is in my signature.
i honestly don't know what is better. recently i went on u pull and pay's web site and found four legacys, one is a 1990, the second is a 1992 and the last two are 1995's . will any of these work ?
The 4.11 ratio transmission has a history of fail when used in an SVX.
how do i know which one has an ej25 ?
the stage 2 4eat came out in 99 ,some SUS have early ones to ,like stated before dont use one with the filter /acumulator mounted on the side and you need to match the gear ratio,all so 95 cars can be 390 0r 411 ,444 started later
if the car came with a 2.5 four banger
the junkyards have to keep that info for the transmissions they pull |
3.90 is only on FWD... and the stage 2's came out mid-year 98 as OT said...
I got one right!
so don't use anything under 1998 ??? sorry i'm a noob to svx's
No, you can't use anything with a spin on filter!
The phase2 came out in mid 1998, and has a spin on filter on the left side, this is the transmission that you can not use. If it has a spin on filter on the transmission you will not be able to make it work without rewiring the car! If the 96,97,early 98 Subaru has a 2.5 engine, then it has a 4.44 transmission. We are talking Legacy GT, Legacy GT Limited, Legacy Outback, Legacy Outback Limited, Forester, Impreza 2.5. I have heard from a Subaru expert that the Legacy LSI has the 4.11 transmission, but do not know for sure if that is true for all of the LSIs.
there is a legacy outback in the u pull and pay here in orlando and it's a 95'. so i have to pull the transmission and the diff , and once i do that what do i have to do to the diff to make work ?
Thread Tools | |
Display Modes | |
