Old 11-30-2009, 08:42 PM
Wocketman Wocketman is offline
Tranny questions...a couple of em
Question #1) Sometimes it slips between 2nd & 3rd, allowing a bit of a rev-up but not that much, and only when under low load. Doesn't seem to happen when accelerating even moderately. Can this be improved by the "band adjustment"?
Question #2) When the OD or torque converter engages (this only happens after several miles of driving to warm up the tranny), I hear a distinct "groaning" or growling noise. Seems to work fine, but the noise is worrisome.
Comments or advice?
Thanks in advance!
Bruce Schwab
Recovering solo ocean racer
www.bruceschwab.com
On land: 92 Ebony SVX, 188k
Old 11-30-2009, 11:11 PM
Re: Tranny questions...a couple of em
yes, you should adjust the brake band to help the slipping. Don't wait too long as usually the simple fact that it is out of adjustment and slipping could mean it is already too late for the adjustment.
Can't help you with #2
-Nate
Old 12-01-2009, 04:30 AM
-Nate
Yikes. It's been doing #1 for years...
And, #2 seems to be louder lately...
Bruce Schwab
www.bruceschwab.com
Old 12-01-2009, 02:18 PM
Comments or advice?
Thanks in advance!
Bruce
It may be that you have a cracked flex plate. If so you would need to be fitting a new one. If it totally breaks you are on the side of the road.
http://www.subaru-svx.net/photos/fil...iles/27764.jpg
You could ask svxfiles or YT about this. I understand there is a newer tougher plate available now.
Old 12-01-2009, 03:02 PM
Bruce
Uh...where is that flex plate? Could it be checked while doing the band adjustment?
I noticed today that I had a distinct vibration at exactly 60mph, that went away at greater or lesser speed. I do have a fair bit of left front bearing noise, I was wondering if a worn out bearing would have that vibration at a particular speed? Have just done the rear bearings...glad THAT'S over...
Bruce Schwab
www.bruceschwab.com
Old 12-01-2009, 03:17 PM
No the box has to come out to check it. It's like a flywheel in a manual car, but lighter.
http://www.subaru-svx.net/photos/use...svxfiles|27762
Old 12-01-2009, 03:40 PM
Bruce
Originally Posted by yt View Post
If you have your engine and/or transmission out this is a required purchase.
Subaru Part #12332AA071
This is the Phase II flex plate that is a direct bolt up for our engines and our Phase I transmissions...
The old style plates are 2.05mm thick according to my micrometer
The new style plates are 3.25mm thick
Just figured someone may need this info. If you have a hard time finding one, let me know, I ordered 3 and need one, so there are two on the shelf
This is YT's post.
Old 12-01-2009, 05:53 PM
If it's a rebuilt tranny (done at 90,000 miles), would it have been the thicker plate?
Bruce Schwab
www.bruceschwab.com
Old 12-01-2009, 06:04 PM
Very unlikely.
As very few people know that these fit.
Display Modes
