Old 08-22-2009, 02:23 PM
stallion stallion is offline
Disconnecting Rear Driveshaft for Towing ?
Hi All,
I was wondering if anyone could give me a quick How-To to go about this to prepare the SVX for towing (and anythign else I need to do). I did a search and couldn't find nada, only suggestions about doing it in order to tow... but nothing indepth for the mechanically-challenged lol.
Old 08-22-2009, 02:36 PM
Re: Disconnecting Rear Driveshaft for Towing ?
Originally Posted by stallion View Post
Hi All,
Assuming that you are going to use a tow dolly so that the front tires do not contact the ground/road, just remove the four driveshaft nuts at the driveshaft flange to rear differential flange with a 12mm wrench.
Then move the driveshaft aside and secure it to , say the exhaust so that it does not rub against the spinning read diff flange.
If you are NOT using a tow dolly, let us know as the procedure is different.
Old 08-22-2009, 03:29 PM
This is EXACTLY what i was looking for. Thanks a million!!!!
Old 08-23-2009, 06:46 PM
NiftySVX NiftySVX is offline
Be careful because the car will drag the back bumper on the ground easily, they warn you in the owners manual about it. I've seen this happen with a SVX on a tow truck.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 08-23-2009, 07:21 PM
But it should never happen with a tow dolly.
Old 08-23-2009, 09:21 PM
Green1995SVX's Avatar
Nate-
A tow dolly will not generate nearly a steep enough angle to cause the rear bumper to scrape.
Mike
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 08-24-2009, 10:32 AM
No it wouldn't, but I felt it should be noted as useful and relevant information should anyone be reading or come across the thread searching for what they might need to do if they were going to tow the car with 2 wheels off the ground, in case someone disregarded the warning about doing so because they assumed that it was simply because of the AWD. I experienced this exact thing happen when someone had their FWD 94 towed to me, the back bumper was ground down and the exaust was damaged. The owner had to pay to have it fixed, and he said he knew that the car wasn't supposed to be towed that way but that he thought that applied to AWD models only.
Old 08-24-2009, 04:17 PM
Good point.
Old 08-24-2009, 05:23 PM
oab_au oab_au is offline
Not only but also. If it is a VTD AWD, you can't tow it any distance at all, on the rear or front wheels. It will destroy the center diff.
One Arm Bloke.
Tell it like it is!
Old 08-24-2009, 06:14 PM
Trevor's Avatar
Trevor Trevor is offline
You can tow a VTD for a short distance and at a low speed. A longer distance at speed will give the centre diff. a hard time, "but destroy it," is rather an exaggeration.
However, if a late model Australian model VTD is involved, and a claimed change in the C solenoid valve is correct, the centre diff. clutch could certainly suffer in a big way, depending on a build up of pressure.
Trevor, New Zealand.
Old 08-24-2009, 08:05 PM
Harvey, if the driveshaft is disconnected, and there is no thing connecting the transmission to the on the road wheel that are turning.....
Old 08-24-2009, 08:06 PM
Trevor, if the driveshaft is disconnected, and there is no thing connecting the transmission to the on the road wheel that are turning.....
Old 08-24-2009, 08:45 PM
Trevor's Avatar
You do not have a problem.
Old 08-24-2009, 09:47 PM
Or if it is put on a all up lift truck, and nothing is on the road,,,,,,,,,,
One Arm Bloke.
Tell it like it is!
Old 08-24-2009, 11:04 PM
Trevor's Avatar
As altered by Harvey
I note that falsifying a members post, by changing the address, is in order, if one can gain a point.
Only if the truck can fly.
