Replacement spark plug boots?
I need to do my plugs and valve cover gaskets soon. So, I went looking for new spark plug boots, but to no avail. Searching indicates that Subaru doesn't sell them separately, and you have to get new coils if you want new boots. I found a few threads with people who had the same problem, but no good alternates to OEM boots were located at that time. But, these threads were a few years old - are there still no boots to be had, or has someone found something since then?
There were some mumblings about a universal plug wire set with a single boot (for the distributor wire) that works, but it sucks buying a whole wire set for $40+ just to get one boot and then throwing the rest out. I found a post where someone listed the dimensions - 1.5" length, 3/8" ID over the plug, 5/8" ID over the coil. With these dimensions in-hand, I searched all over the internet, but found nothing. Called MSD's tech line - they didn't have anything either. I fired off an email to Accel, but haven't heard back yet (and am not really expecting anything either). Does anyone know if there is anything out there that works?
Re: Replacement spark plug boots?
Ummmmmm....The SVX doesn't have a distributor. It's a coil-on-plug ignition, so there are 6 individual coils sitting right on the spark plugs. The boot is part of the coil, they are molded in together and don't come apart.
I was under the impression that the boot slipped over the end of the plug, and also over the end of the coil pack though - not molded as part of the coil. I haven't pulled mine out to look at them, but everything I've read suggests that the boot is replaceable - just not available separately.
When I replaced the plugs on my car I didn't notice if the boots are removable, although I didn't pull on them to check.
As far as I know, the boots are not replaceable. You have to get new coils to replace them.
I have a somewhat rough idle, and some driveability problems. I have reason to suspect bad plugs or a coil arcing...hopefully it's just plugs. When I got my car, the previous owner gave me 3 (yes, 3) new spark plugs with it...so I'm probably running on 3 fairly new plugs, and 3 with who knows how many miles on them. I guess I'll see when I tear into it.
they are removable but I am not sure if they are a servicable part w/o the coil. I will check and report back
Tom |
Priceless hahahaha, maybe he got halfway through the oil changes and gave THAT up too I guess I cant talk....my new plugs have been sitting on my shop bench for 6 weeks now
No dice, I will try and call my parts dept. tomorrow and see if they might be special order
Tom |
I will reserve final judgement on the possibility of a coil / boot being bad until I get new plugs in there and also am able to inspect the coil boots. I'll see how it runs after dropping new plugs in. Quote:
bOSH+4'S also run like total ass if the engine is not up to temp. Change them out, while you are at it grease the boots and pay attention to the condition of the wire going to the coil
Tom |
I'm also hoping that going through the ignition will finally fix my crappy mileage, since that seems to be the only thing left to look at. I just pulled the best mileage I've ever gotten in this car at my last fillup - a fuel-sipping 14.5 MPG. This is with brand new left and right OEM O2 sensors, a new air filter in the stock airbox, and a new OEM coolant temp sensor as well. Quote:
The road to recovery is a long one in this case...I've been all over this car fixing different things nearly every weekend since I got it (at least every weekend above 45 degrees, anyway), and still have a laundry list of stuff that needs attention. Slowly knocking it down though.
when i changed my plugs a couple years ago one of the boots stayed in the head. it was a bear to get out and i used a mirror and a pick to pull it out in pieces. i bought a couple of new ones from subaruparts so now i have a spare.when i put the new boot on i used a fair amount a dielectric grease to hopefully prevent this again.i put grease on all the others as well. hope this helps.
I'm about to start changing my plugs right now and after 17 years I'm sure at least one of the boots will be bad...
Here is a pic of the coil w/ boot I'm sure I'll be at the parts store later today looking for something to substitute for the boot One thought...here is an 07 tribeca coil on plug: Not exactly the same, but the boot looks kind of like a standard spark plug boot ...
'93 Anniversary Edition SVX 122k - 3.7 FD 5MT Swap, ECUtune 1a1, Bontrager RSB, Mad Restoration underway! '20 Honda Ridgeline Custom Oil Caps, Battery Bars, Phenolic Spacers for sale here: http://www.x35design.com Last edited by Stevebsy; 06-13-2009 at 11:37 AM. |
