Old 03-09-2009, 06:02 PM
rallyingrob's Avatar
rallyingrob rallyingrob is offline
will 4eat front pinion fit 5mt?
i REALLLLY want to keep my 4.44 gears!
but i also want to swap in a 5mt!
i figure the 5mt from something OTHER than a WRX would be the way to go...i understand that the WRX has the front step-down gearing (or step-up?)...
but that the other 5mt's do not?
(i'm thinking legacy turbo donor car...unless there is a better non-wrx alternative?)
the question is:
can i yank the front pinion from my 4eat (4.44) and install it (with the rest of the front diff) into a 5mt?
indeed...will the 4eat diff even fit in a 5mt at all?
or..........
is there a better way for me to achieve 4.44 final drive with a manual transmission?
just wondering.....
i'm too svxy for my car
rob
92 ebony 4.44's rock !!
Old 03-09-2009, 06:21 PM
Re: will 4eat front pinion fit 5mt?
Subaru did make some AWD 4.44 manual transmissions.
But the overdrive ratio is higher, making them very high winding.
This link should help.
http://spda-online.ca/modules/tinyco...ite/tc_28.html
Old 03-09-2009, 08:48 PM
No you cannot use the pinion from an AT w/ an MT
Old 03-10-2009, 10:10 AM
thanks tom !!
and thanks svxfiles!!
ok then...now the question is:
which is "better"....a push type clutch?
or pull type...?
which is easier/more common to source?
the tall 5th gear is no biggie....this is for the rally-beastie...
so i'll likely not be using 5th gear anyway
(if i do, then i'm going WAAAAAAAAAAYYYY too fast !!!)
lol
rob
Old 03-10-2009, 10:57 AM
The Turbo Forester, and Turbo Baja came with a 4.44 MT.....
Old 03-11-2009, 07:23 PM
in the words of c montgomery burns...
"Exxxxcellent!"
rob
Old 03-11-2009, 07:59 PM
kwren's Avatar
kwren kwren is offline
Wasn't it Montgomery that was Patton in the movie, "Patton"?
Old 03-12-2009, 07:55 AM
ummmm
george c. scott wasnt it?
rob
Old 03-15-2009, 11:39 AM
Splinter Splinter is offline
I have a V4 STI Type RA 5 speed for sale. 4.44 final drive with DCCD, $1500 for the trans and rear diff (not parting out)
Old 03-15-2009, 06:11 PM
subeman90's Avatar
Soobologist
regular baja non turbo's have 4.44's too (atleast the 06's do)
15 OBW premium w/eyesight
Old 03-15-2009, 07:15 PM
Not the 5-speeds.....or it's news to me...
Old 03-15-2009, 07:36 PM
subeman90's Avatar
Soobologist
if you saw what my tach reads at 70 mph you would swear I'm right. where can I find that info.?
And for anyone else out there following along: mine is 5 speed
Old 03-15-2009, 08:06 PM
http://www.subaru-svx.net/photos/user.php?How-To|44897
Look in that folder...I think that is the list of manual trannys...and the only US cars with a 4.44 MT is teh turbo Baja, and Turbo Forester....
Your Baja, probably has the same tranny as a RS which has a lower 5th then a standard Legacy 5-speed...
Old 03-17-2009, 10:06 AM
subeman90's Avatar
Soobologist
here is the info I have gathered about the baja transmissions.
http://forums.nasioc.com/forums/show...1#post25980423
Old 03-17-2009, 11:08 AM
I'm going by this chart:
http://74.125.47.132/search?q=cache:...ient=firefox-a
Which shows only the Turbo Baja, and Turbo Forester (in the US) got 4.44, all others are either 4.11 or 3.90s....
