Wheel Bearings...Front & Rear??
I am sure someone is going to holla at me for not searching this before asking...LOL I can hardly hear when running 60/70 MPH in my car, the bearings are SHOT and im just hoping my hubby is trying to scare me telling me it will weld to the housing and something will come out from under it and the wheel and all will come off and if im running 60/70 I will probably be flipping...(is this true) <p>More importantly can someone send me the best local place and the numbers of the bearings so I can order them or call about them tomorrow. I need to write a check so I would rather get them here. Does the seals or whatever I need come with them and do I need front n rear? Can I get away with doing rear only? (for a couple weeks) <p>Any help is appreciated, I will print it in the AM and order them tomorrow....THANKS!
Life begins around 70 MPH and stops when you dont see the flashing blue lights anymore! Scott & Audrey's Subaru SVX's 1995 Green 1992 Black |
Search for wheel bearings. You'll need a bearing, 1 inner and 1 outer seal per wheel. ALWAYS have a subaru dealership replace them, or find a shop that has a hub tamer tool to replace them properly or you'll be replacing them again soon. (DO NOT USE A PRESS) Most independent shops won't have this special tool and even if they did they won't know to use it on this car, but it is the only way to fix them properly. Subaru put out a bulletin on this. Additionally, the sealing surface of the axle may have a groove worn in it that will require axle replacement.
You should realy talk to Tom SVXfiles about this. If you can get your car there, he'll do a great job.
I advised him not to drive it that far, about 100 miles, and he insisted we go all the way to my shop. WITHOUT STOPPING ONCE!!! 2.6 miles from my home the rr axle boot caught FIRE!!!!! And fell out from under the car. The heat was generated by the parking brake shoes rubbing on the inside of the rr brake rotor. The axle, wheel bearing, rr hub, parking brake cable, ABS sensor, rotor, backing plate, caliper mounting bracket, and more were ruined. That being said, are you sure its a wheel bearing? Who did the diagnosis? Bad tires can make the same exact sound. Do you have four jack stands? What county are you in? I have a list of part #s in another thread and will post it here for you in my next post. Tom Here is the parts list; $105.00 labor, $66.33 for a rear Subaru bearing.#28016PA010 $7.06 for Subaru seal #28015AA070 $8.56 for Subaru seal #28015AA080 $3.50 for Subaru wheel nut #28044AA001 $42.00 for steaming, degreasing, repacking and pressing the new bearing. $4.28 tax $236.73 Total.
www.svxfiles.com The first SuperCharged SVX, the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway Fiberglass Hood thread My locker 4.44 Swap link Last edited by svxfiles; 10-24-2007 at 08:13 PM. |
I've driven both of mine for weeks with the faint-but-telltale roar of a bearing going bad, but if they're that loud you really need to have them replaced ASAP. I'd get a second opinion from a good mechanic before replacing both the fronts and rears.
dcb |
Who did the diagnosis? Um ....ME...well, yall...cause I learn so much from you guys. Just kiddin, tell me what I need to do, its got 150,000 and believe me I would love to learn its NOT the bearings because I DO NOT have the $$$ right now. At this point I need someone to put the belt tensioner bolt back on my black car and put that on the road , but I DO love my green car, and its got my music, and everything like I want it. So help me out here TOm...Oh and Subaru will NOT be doing them either way NiftySVX..sorry I dont go that way...
Timken wheel bearings
I did the rears only on my Red 96 Lsi. They werent noisy yet, but just preventative maintenance and peace of mind. Plus we were overhaulin the entire brake system, and it just seemed like a good idea to put in fresh bearings. I went with the Timken brand, which cost me $45 each, and labor was $80 a side. So I got both rear sides done for $250 parts and labor. Great deal, and a great mechanic as well. Stay away from the Subaru dealer, they know very little to none about working on an SVX. If your close to SVXfiles, take it there, you will have peace of mind for sure.
1995 POLO LSI 76K MILES SOLD |
But by all means take it to SVXfiles, he knows all the tricks. Bob's auto repair probably doesn't care to pay for alldata, and even if they did, they wouldn't bother to look up technical bulletins for replacing the wheel bearing. And even if they did that, they wouldn't buy a $500 dollar tool just for Subarus. But go ahead and press them in, indent the inner race and out of round the knuckle. See you in 20-50k miles for the next set.
2007 GS 450h-Active Stabilizer/Radar cruise 1994 L Blue 3.70 VTD ASE Master Automobile ASE Advanced Level Specialist Toyota Master Diagnostic Technician (former life) Last edited by NiftySVX; 10-25-2007 at 12:54 PM. |
yep, replaced them a year ago and i'm hearing a slight whining in the rear... trying to tell myself its the tires, but I know deep in my heart its time to add wheel bearings to the standard wear replacement list... oh well at least I can skimp on the axle nuts this time
1992 Pearl White/Black Onyx Subaru Alcyone SVX LS-L Donating Forum Member In Good Standing JDM 4.11 Geared Transmission JDM 'ALCYONE' Rear Panel JDM 'BOXER' Eingngine Cover JDM 'SVX' Hood Badge L-Edition Suede Rear Seats |
I was hurting in the wallet department when my bearings started acting up. I drove with them screaming for several months. The thing was like driving a sherman tank. No need to bother with the radio because no volume was loud enough to drown out the bearing noise. Fortunately, no harm done. I took them to a local shop and they had them swapped out in a matter of hours. It came up to about $400 for both rear wheels.
I've been in this little community since before this site existed, in fact, for those who remember when we were a yahoo group, i was there. SALES people may not know about the SVX, but the service people will. I have many years of experience and more certifications than I can remember, as well as over 100 college hours in automotive technology. I've personally replaced more wheel bearings than you could count. I don't work for Subaru, I AM TRYING TO WORK FOR YOU SO YOU CAN HAVE YOUR CAR FIXED PROPERLY AND NOT HAVE TO DO IT AGAIN SOON. I do this because I have experience that I don't think many on here do. END OF RANT
you are not ranting, you are saving us money while helping us keep our ladies up and running. wheel bearings are a common problem on these ladies and not replacing them every 30,000 miles is a large help. i have driven on a bad wheel bearings till they made so much noise you could not talk over them which was a bad idea as when they were replaced I also had to replace the hub but is extreme situation
William |
