Old 11-08-2006, 01:15 PM
mikecg's Avatar
mikecg mikecg is offline
Send a message via AIM to mikecg Send a message via Yahoo to mikecg
If you have a stock ECU, your tranny will never shift at 7000rpms. Stock ecu cuts out lower then that. ECUTne ECU have a raise rev limit of something like 7200rpms at the request of the manual guys.
Old 11-08-2006, 03:04 PM
sharky512345 sharky512345 is offline
Send a message via AIM to sharky512345
The stock ECU will let the SVX rev to 7000 rpms. My stock ECU will not shift higher than 6500 rpms if it is in drive. If i'm in 1,2, or 3 then my stock ECU will be allowed to rev to 7000 rpms, where it will bounce off of the rev limiter.
Current: 2005 Black Legacy 2.5i 63k
Previous: 1996 Brilliant Red SVX LSi 117k
Old 11-08-2006, 07:13 PM
Ira Davis's Avatar
Ira Davis Ira Davis is offline
Peace Sells... are you buying?
Normally I don't tend to say much, I just sit back and take it all in; but this time I think I'll enter the fray.
First I see no reason why shifting gear to gear would harm any automatic transmission. It's designed to be able to do that; however if you don't have a manual valve body (a modified valve body, which allows the operator to determine shift points) I don't really see what the benefit would be. At this point I don't own an SVX (about to change) but I assume that the computer still controlls the shift points like in every other electronically controlled transmission.
Now as someone who has built and dynoed several automatic transmissions I would agree that power braking might not be the thing you want to do in a stock SVX.
These are just my opinions of course, so take it with a grain of salt.
Off subject (sort of) but has anyone thought of having an SVX automatic modified with a manual valve body? As I am about to buy a couple of SVXs I think that might be a project I am willing to take on. Never ripped apart a Subaru automatic before but it functions the same as any other automatic does, which means in theory it can be done. What would the benefit be? Manual shifting; of course!
Now out of curiosity where can I get a manual that details the rebuild of a 4EAT? Basically I need to have flow charts for the clutch packs etc.
Old 11-08-2006, 10:21 PM
Best way to manually shift?
With your left foot on the clutch and your right on the shifter silly
Old 11-08-2006, 10:44 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Send a message via AIM to Budfreak
I have never EVER seen my car hit 7K RPM till I got stage 1V4. Now every now and again it will snap off a nice shift at 7K and it feels like it's pulling strong all the way. I think on my record time run I hit 7K on the 2-3 shift. Wish they could come up with a way of reprogramming the TCU to shift higher.
BTW, The thump or bang you hear when you let off at high RPM could be a tranny mount needing replaced.
Old 11-08-2006, 11:28 PM
Manarius's Avatar
Manarius Manarius is offline
Originally Posted by Earthworm
If I left the shifter in 3rd it would shift to 4th at 210kph instead of 200kph. It took noticably longer to reach 210kph when it shifted at 200kph.
That's courtesy of having to dig out of 3rd at that point in time. It's still way out of the torque range. Do you think people trying to get max dig out of their 5MT's shift at redline? No. They shift when the torque band runs out. I know my Legacy has no dig after 5500...it's just running out the end of the gear.
-Jason
-Obi Wan Kenobi
Old 11-09-2006, 08:13 AM
manarius is right. I still rarely take it to 6500 even... just not worth it as there is no power there
Old 11-09-2006, 03:42 PM
oab_au oab_au is offline
Well Tom, thats why we did the inlet cams, to extend the torque further up the rev range.
One Arm Bloke.
Tell it like it is!
Old 11-09-2006, 05:30 PM
n00b on demand's Avatar
So basically if it says that your car reaches max horse power at 5500 RPMS, thats where you shift?
Old 11-09-2006, 08:58 PM
Who did, I install 3 sets of cams... THey are not in any cars that are still auto... Anyone else should be shifting sooner than later
Old 11-11-2006, 05:15 PM
LOL. Exactly.
The only time I shift when driving one of the Foresters in my garage (parents, grandfathers) is to control speed (hills, engine braking..). Occasionally when going through curves I'll pull it down to get it into a lower gear sooner than just flooring it would do.
