Re: DDM Tuning (Apexcone HID's)
I just order online from the site..... ill check their contact info later.....
On a related note, I JUST got my refund from them TODAY.... which I thought I was getting 4/12 when they figured out my shipment went to Northridge..... THANKS FOR HOLDING ON TO THAT FOR A WEEK!!! DDM Tuning... beware
Chris "A person convinced against their will, is of the same opinion still" ![]() ![]() |
I ordered my Hid slims from DDM without a probelm. Just my 2 cents.
I've never dealt with them through online orders. On a review basis I have seen the horror stories posted on some forums with online orders. Luckily for me, there are two stores in the San Diego area and they always have parts for the 35w kits in stock. Now if you attempt buying 55W kits on site, those are shipped from CHINA. SVX(4+ years 35w slim) and my brothers E36(3+ years on 35w slim).
Sam Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners My Locker |
Just want to say I have 6000k HIDs from DDM and have had absolutely no issues. I haven't gotten flashed by other drivers for them and I haven't been harassed by cops for them and believe me, my local police love to give you a hard time for whatever they can think of.
SoobCrazy, you do know our low beam housing is a projector not a reflector housing, right?...
I put HIDs in mine and was pretty happy with the improvement. Nobody flashed me thinking I had brights on, but that doesn't mean that much. Not everybody will flash, and also the car is very low while most cars and SUVs have gotten taller. After a few months I started having some weird intermittent issues with them failing to turning on, which turned out not to be the HIDs but a bad alternator. I ended up taking them out and going back to standard bulb as a troubleshooting measure and decided not to put them back due to the uncertainty of whether they should be used or not.
It would be interesting if someone who knew about this stuff could actually test the SVX's light patterns with and and without HID and give us a comparison. I am really curious if it really is a problem or not. They are a pretty common upgrade and it would be nice to see better at night.
OK, now I'll lay this out for you as simply as I can: It does not matter the physical style of lamp, whether it is a reflector, projector, free-form reflector or anything else. If the lamp was designed for a halogen bulb, you CANNOT simply swap in an HID or LED bulb and go. The problem with swapping in bulbs of different construction is that the lamp housing was designed for the specific shape of the light source produced by the bulb. Halogen lamps use filaments, shaped like a line "l". HIDs produce an arc of electricity ")". LEDs produce a single point of light "." So, when you put a HID/LED bulb into a halogen lamp what happens? As the light leaves its source the first thing it will hit is the reflector. Now this reflector was specifically designed and tuned to bounce the light and re-aim it to the correct spot down the road. IF the light hits the reflector from a new angle, there is no chance the light will be re-aimed properly. "But my lamps have projectors!" you cry. That doesn't matter at all. The projector and its reflector, and the geometry designed into the assembly, are still designed for a halogen bulb. Quote:
If you honestly want to improve your night vision here are your options: 1) Install better halogen bulbs. 2) Bake open your headlamp housings and retrofit in an HID or LED lamp assembly from a vehicle with those lamps factory-installed. 3) Add appropriate auxiliary lighting and cover when not in use (Driving lamps, etc.) We are all "the other driver," so be thoughtful and courteous with your modifications. I highly suggest everyone look a little deeper at lighting "upgrades" in the future. Just because it's cheap, easy to do and everyone around you is doing it, doesn't mean it's correct or safe. |
What are the "better" halogen lamp options?
You could use a 9005 bulb in place of the 9006 in that projector, for more lumens, while maintaining the correct filament location-
![]() 1997 Ebony #308 113k "The Black Diva"SOLD ![]() 1992 Black over Liquid Silver 152k SOLD ![]() 1992 Ebony 251k 444 SOLD ![]() 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
lol you can't tell me that HIDs aren't a good upgrade just because our housings weren't meant for that shape of light pattern. It may not be as optimized as can be but they're so much better than halogens. First time driving a car with stock headlights after being so used to my HIDs I thought I only had the fogs on!
HIDs in our cars are a big improvement, they don't blind other drivers and in my experience, they have not garnered any attention from cops. I dont care what the math says lol |
Out here in rural country I prefer the a$$ kicking HIDs at the lower temperature ranges. On the Claret she has 4300k low beams and 5000k high beams, and when I am out with my 60yo brown eyes, after 45 or more years of welding, it makes my driving safer for everybody! And, no I have not been flashed by other drivers. Their 3' off the ground factory installed HIDs blind me, but they are legal.
#28
"A halogen bulb has a cylindrical light source: the glowing filament. The space immediately surrounding the cylinder of light is completely dark, and so the sharpest contrast between bright and dark is along the edges of the cylinder of light. The ends of the filament cylinder fade from bright to dark. An HID bulb, on the other hand, has a crescent-shaped light source -- the arc. It's crescent-shaped because as it passes through the space between the two electrodes, its heat causes it to try to rise. The space immediately surrounding the crescent of light glows in layers...the closer to the crescent of light, the brighter the glow. The ends of the arc crescent are the brightest points, and immediately beyond these points is completely dark, so the sharpest contrast between bright and dark is at the ends of the crescent of light. This diagram shows the very different characteristics of the filament vs. the arc: ![]() When designing the optics (lens and/or reflector) for a lamp, the characteristics of the light source are the driving factor around which everything else must be engineered. If you go and change the light source, you've done the equivalent of putting on somebody else's eyeglasses: You can probably make them fit on your face OK, but you won't see properly. Here are some downloadable PDF tests done by DOT and CalCoast Labs on halogen headlamps equipped with "HID kits": Test #1, with 9004 "HID kit" vs. 9004 bulb Test #2, with 9006 "HID kit" vs. 9006 bulb Test #3, with 9004 "HID kit" vs. 9004 bulb And here is a documentary done by Auto Express showing the results of installing "HID kits" in UN ("ECE", "E-code", "European") headlamps, which are designed for notably tight control of glare on low beam: https://www.youtube.com/watch?featur...&v=Y5n38wDe684 Now, what about those "retrofit" jobs in which the beam cutoff still appears sharp? Don't be fooled; it's an error to judge a beam pattern solely by its cutoff. In many lamps, especially the projector types, the cutoff will remain the same regardless of what light source is behind it. Halogen bulb, HID capsule, cigarette lighter, firefly, hold it up to the sun—whatever. That's because of the way a projector lamp works. The cutoff is simply the projected image of a piece of metal running side-to-side behind the lens. Where the optics come in is in distributing the light under the cutoff. And, as with all other automotive lamps (and, in fact, all optical instruments), the optics are calculated based not just on where the light source is within the lamp (focal length) but also the specific photometric characteristics of the light source...which parts of it are brighter, which parts of it are darker, where the boundaries of the light source are, whether the boundaries are sharp or fuzzy, the shape of the light source, and so forth." Read up, gain knowledge, profit. |
#29
1995 Caterham 7 Twincam 2002 Porsche 911 targa -- now with FSI 4.0L power! 2007 BMW 328i Cabriolet 2012 Tacoma 4wd v6 Access Cab 2013 Mercedes E350 4Matic Wagon 2005 STi - totaled after 10 great years 1994 SVX LSi 5spd - sold but not forgotten 2000 Legacy GT 5spd sedan - gone after 150K miles of bliss Last edited by wdb; 12-01-2016 at 04:01 PM. |
#30
1997 Boudreaux LSi 1994 SVX LSi(SOLD) Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3 |
