Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Interior Mods
Old 06-21-2012, 01:56 AM
Gauges
They are from prosport, and I used a oil filter adapter for the oil pressure and temp gauges. I also got a oil galley plug, so once I get the other motor built, I will put the gauge directly in the block. They are the 45mm ones, which I got because I really don't see anywhere else in the SVX interior other than a DIN slot that they wouldn't look completely out of place and awkward. Once I have the water temp gauge hooked up I will take a video.
As far as installation, I just used a sheet of plastic (actually a mouspad I don't like at all) I had and cut/folded it into the shape of a DIN slot, then cut circles in it. The color and texture look like what you'd expect to see in a car, so I guess it works.
Old 06-21-2012, 02:11 AM
Subix's Avatar
Subix Subix is offline
My Other car is a GENIUS Car!
Re: Gauges
Nice work! They look good! Looking forward to seeing the video for sure!
1994 subaru svx le 112k
Old 06-21-2012, 02:14 AM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
Re: Gauges
Sir, you have a game that ruins lives in your passenger footwell. You're going to have to get rid of that asap.
Old 06-21-2012, 07:36 AM
Re: Gauges
VERY nice I like it. I have one Gage , the one to the left of the cluster, that was originally for Tranny temp. since I no longer have a Auto tranny, I need to replace it or set it up for another use ?????? Any suggestions?
Old 06-21-2012, 11:19 AM
92 SVX 92 SVX is offline
Re: Gauges
Not sure if they make them for the svx but a pillar 3 gauge pod would probably work better, looking down that far to see them just seems like asking for trouble lol
Old 06-21-2012, 11:38 AM
Re: Gauges
Nah those look silly (IMHO, of course - to each his own). Not going to be looking at them all the time anyway.
Conn, those look good. Yet another thing that's very similar about our cars. Yours look a little bit bigger though, right? You have a white back speedo/tach, right? Bet the gauges match nicely then.
Your trans temp one, you might be able to re-purpose, but I'm not sure. What brand are they?
Thanks, all. Gonna try and finish up the rest tonight.
Old 06-21-2012, 11:45 AM
Re: Gauges
I'd go with either an actual coolant temp instead of the dummy gauge so you can see an actual temp, or otherwise oil temp if either aren't covered by the other gauges.
Re: Gauges
That would be WC3, not WoW, sir. Can only be described as a well-aged classic. A friend of mine had it sliding around in the trunk of his Altima for like 4 years, and cleaned the car out next to mine. Guess where it ended up. Not sure what to do with it.
Old 06-21-2012, 11:46 AM
Re: Gauges
Nate, you're going to laugh when you get here and see where I ran the wires... :P
Old 06-21-2012, 11:52 AM
Tapani Tapani is offline
Re: Gauges
Innovate wide band and boost
T
Old 06-21-2012, 12:36 PM
Re: Gauges
I'm intrigued...
Old 06-21-2012, 02:38 PM
Chuckls's Avatar
Designated Asshole
Re: Gauges
I just saw Warcraft. Either way...DOWN WITH BLIZZARD
Old 06-21-2012, 03:12 PM
Re: Gauges
Now have amp and vac. Where do they get the temp.for tranny taken from? Could I move the sensor to the oil?
Old 06-21-2012, 07:59 PM
Re: Gauges
Before WoW, blizzard was a very different type of company. Like, night-and-day.
Old 06-27-2012, 09:00 AM
Re: Gauges
Mine are Summit VDO gauges. The dash is Procarparts reverse Euro indigo
