#31
Re: Increasing Compression
Cp in USA Will do whatever you wish after you send em your stock piston for base. $$$$ though |
#32
CP pistons doesn't need a base any more, they have done enough EG33 pistons by now.
#33
Indeed, however you only get sub 10:1 compression pistons for their on file designs.
#34
baza,
You may not know but I am building a engine dyno so at the end of the day it will be easier for me to shave the head and that way I can play around with different compression ratios. So guys how much do I need to shave off? Tony
#35
What a top idea. Have you got a thread detailing this build, I'd be very interested
#36
Removing the 0.060" head geaket will only drop it 1.87cc. Harvey.
One Arm Bloke. Tell it like it is! 95 Lsi. Bordeaux Pearl, Aust. RHD.149,000Kls Subaru BBS wheels. 97 Liberty GX Auto sedan. 320,000Kls. 04 Liberty 30R Auto Premium. 92.000kls. Last edited by oab_au; 05-30-2012 at 11:40 PM. Reason: If I didn't fix the metric/Imperial fault. Tom would. |
#37
here,
http://www.subaru-svx.net/forum/showthread.php?t=54640 I have been as "flat out as a lizard drinking" over the last year but plan to get back to it soon. I have worked out soluations in my head. Tony
#38
Okay some rough numbers.
3,318 Litre 6 Cyclinder 97 mm Bore 7.3928 Area of piston Target compression Final Volume Difference MM to Shave Current 10 55 11 50 5 0.680 12 46 9 1.247 13 43 13 1.726 14 40 16 2.137 15 37 18 2.493 I think there maybe mistakes so if so please yell. Tony
#39
Here is some more info,
It might make more sense in the JPG. Spoke to the guys with the cam pullies and they allow plus & minus 12degree adjustment. According to my calcs if you were to run 15:1 the left bank would need 7.8 degree of adjustment. Okay were am I at. Shave heads is the only way to go because I have a lot of heads and I can experment with different compression ratio with little effort. I can just put them in my cnc mill and plan them off. The pullies will enable adjustments simply. Have a great day all. Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. Last edited by Dessertrunner; 06-02-2012 at 12:54 AM. |
#40
detail of calcs
#41
You would need to cc the chamber to see what volume that shaved 0.5mm would be. Harvey.
#42
Good point Harvey you are right.
Do you agree with the basic Logic on timing adjustment or did I get that wrong.
#43
#44
Admittedly it has direct injection, which allows a higher compression ratio, but the latest Subaru BRZ/Toyota 86 has a boxer Subaru engine with 12.5:1 compression. Might be a target for you Tony? Or are you already past 12.5?
Matt |
#45
I want to go higher Matt, good pice of info. You got to wonder if they can get away then would E85 or direction injection be more likly to be able to go higher compression.
Tony
