Old 03-05-2007, 08:56 AM
SubaruKidSVX's Avatar
SubaruKidSVX SubaruKidSVX is offline
Too many lights!!
My ABS light has been on since I bought the car. We checked everything out and there is no reason for it to be on. How can I get it to turn off? My E brake light came in this morning and will no turn off. The brake is not on and even when I put it on and off it will not turn the light off. Is there something to check under the car to make sure it isn't keeping the light on from the last time I put the E brake on.
Thanks
1992 SVX LS-L 77,000 Miles
1983 Alfa Romeo Gtv6
1990 Alfa Romeo Spider
1973 TVR 2500M
Old 03-05-2007, 09:04 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
The handbrake light is usually caused by this:
http://www.subaru-svx.net/forum/show...00&postcount=6
For the ABS light, read this:
http://www.subaru-svx.net/photos/files/How-To/14364.jpg
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 03-05-2007, 09:24 AM
First, remove the brake master cylinder cap under the hood to check the fluid level.
Then make sure the black diaphram in the cap is not "popped out", or extended beyond the upper cap recess.
It should NOT look like this;
It should look like this;
As far as the ABS light do you know about the built in self checking system?
It is cooler than Elvis on ice!
Old 03-05-2007, 09:33 AM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Oh I see, it should not look like this.
Do you have butter and bread? Is your toaster working? Me so hungry...
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 03-05-2007, 09:54 AM
Good Morning, Ken.
Are you signed up for Reading yet!?
Old 03-05-2007, 03:43 PM
Thanks alot for the input. I don't know anything about the built in check for ABS. The brake light turned off sometime during the day I figure. I got out of school and the light has not turned on since.
1973 TVR 2500M
Old 03-05-2007, 04:14 PM
Check the How-To documents to find out about checking codes.
Old 03-05-2007, 09:32 PM
will do, thanks
1973 TVR 2500M
Old 03-06-2007, 05:30 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Hey let us know what code you are getting with the flashing led.
1995 Subaru Svx L / AWD
Old 03-06-2007, 08:55 AM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
Send a message via AIM to Ricochet Send a message via MSN to Ricochet Send a message via Yahoo to Ricochet
Thanks
Take the bulbs out; I can't believe nobody recommended this yet.
Brian
Old 03-06-2007, 09:18 AM
GOT2HAVESVX's Avatar
GOT2HAVESVX GOT2HAVESVX is offline
What blue lights?
Send a message via AIM to GOT2HAVESVX
Black electrical tape works too, looks REALLY ghetto in the daytime though!
Life begins around 70 MPH and stops when you dont see the flashing blue lights anymore!
Scott & Audrey's Subaru SVX's
1995 Green
1992 Black
Old 03-06-2007, 09:29 AM
We thought about the bulbs...I mean it works but not the best idea. We will try and read them and if we have no luck we will go a different path. This weekend I think is stereo weekend and next weekend will be read light weekend.
1973 TVR 2500M
Old 03-06-2007, 10:49 AM
msvx95's Avatar
It's just a phase
i did that with my airbag light...not a good idea...you should really see what the problem is.
