Old 04-09-2017, 05:52 PM
I have too many parts and not enough money!
Hi Guys,
I have been hoarding Subaru SVX parts since 2001.
I need to sell some of this booty off.
Some of this stuff is brand new, most of it is used.
All of it is presentable and useable.
No, I don’t have any radiators, cam/crank sensors or TPSs to sell.
I have some doors, fenders, trunk lids factory spoilers that need to be repainted, a hood, a brand new factory muffler (all years), a brand new two into one center cat, (96 &97) some interior stuff. Starters, factory fresh head gaskets, one brand new alternator, intake manifolds without IRIS valves, throttle bodies,ECUs, TCUs, ETC, ETC, ETC. Bill’s already LSD’d R160 4.44 that does not whine!
I have a 28’ X 24’ garage attic COVERED with Subaru parts! If you need something, please ask.
I need to make some room, and I need the money.
three oh one seven oh seven three four three seven
Thank you, Tom Krynock aka svxfiles
Old 04-23-2017, 02:06 PM
LarryIII LarryIII is offline
Re: I have too many parts and not enough money!
Tom,
I'm going to send you a PM for the parts I need/want.
Old 04-24-2017, 06:07 AM
theflystyle's Avatar
Tom - PM Sent!
1994 SVX LSi
2008 Legacy 3.0R
Old 05-11-2017, 05:05 PM
flmont flmont is offline
I need a set of engine mounts,.??? Thanks Frank
Old 05-14-2017, 06:35 PM
Hi Frank, do you want stock SVX mounts or MUCH heavier duty ones? three oh one seven oh seven two eight three seven...
Old 05-14-2017, 07:29 PM
Drivers side rear hub assembly and/or a drivers side engine mount? Shipping would be crazy id imagine but id be willing to meet somewhere in west va or if you are available my engine could use a reseal...
Old 05-14-2017, 07:36 PM
"Drivers side rear hub assembly" I actually might have a brand new one in the parts attic! Just gotta climb that ladder.
Old 05-16-2017, 09:30 PM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
Tom - Sent you a PM, haven't heard back. Do you think any of those parts would be of interest for my new build?
____________________________________________
95 LS-i Red, 31,xxx; bone stock for now; Daily Driver
94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light,
2017 Subaru Forester XT, metallic dark gray, 29,xxx
2005 Porsche 911 Turbo S Cabrio, 24,xxx
2006 Subaru Outback LL Bean, 166,xxx sold
92 LSL Dark Teal, Smallcar Shift Kit - sold
Old 06-10-2017, 10:45 AM
rrhenderson's Avatar
rrhenderson rrhenderson is offline
MacArthur
Hi Guys,
Hi, Do you have SVX Ignitor? Need one. Thanks.
Old 06-10-2017, 01:27 PM
SoCoNoHa's Avatar
SoCoNoHa SoCoNoHa is offline
H6 Fanatic
I have not enough parts...or money
Hey Tom, would that 2 into 1 cat work on an obd1?
1992 SVX LS-L : King of the Stable
LGT 5MT, ABS Delete, Short Ram Intake, Custom Exhaust, Drilled/Slotted Rotors
1993 Legacy sedan : winter beater, supposedly.
1994 Legacy wagon : future drift car?
1995 Impreza coupe : EZ30++, daily racecar.
1997 Legacy GT : date night rocket?
2003 WRX : future winter beater
Old 06-15-2017, 06:48 PM
wolfcj wolfcj is offline
Re: I have not enough parts...or money
Sent you a PM about a couple of things I'm looking for.
Old 06-29-2017, 02:05 PM
Scubi2 Scubi2 is offline
Wheels? Center console cup holder? (yes, I'm serious about the cup holder).
PERFECT floor mats?
Old 06-29-2017, 05:52 PM
Perfect floor mats?
OEM GRAY floor mats have been discontinued about 15 years. A new set showed up on eBay in 2011, and sold for an astronomical price.
http://www.subaru-svx.net/forum/show...ray#post692964
I just sold one of my last remaining sets of new, BEIGE still-in-their-original-plastic bags, floor mats last year.
There are great alternatives custom made out there, but no one has the licensing to reproduce the embroidered SVX logo.
Old 10-07-2017, 01:26 PM
Tom,
Do you have the 2 front hood struts that can hold the hood open along with the brackets and attachment hardware? If you do please send me a PM with the price and include shipping costs. You know my address.
Thanks.
Larry
Old 10-08-2017, 07:27 AM
Do you want them new, or used but still work?
