Go Back   The Subaru SVX World Network > SVX Main Forums > Competition Motorsports
Old 03-12-2016, 06:45 PM
Gamesy's Avatar
Gamesy Gamesy is offline
SVX on dyno
Finally was able to get my svx on a dyno to see what stock numbers came up.
it was coming up 122awhp constantly.
Old 03-13-2016, 04:48 AM
Re: SVX on dyno
Sounds about right as there are huge losses in any AWD/4 wheel drive system.
My GMC truck was well over 300 engine horsepower and only had 210 HP at the rear wheels.
Old 03-21-2016, 07:54 AM
sicksubie's Avatar
Re: SVX on dyno
That does not sound right... 47% drivetrain loss? I have never seen that much loss on an SVX. When I benchmarked my SVX's (with the 4EAT) I was right around 150awhp.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 03-21-2016, 02:45 PM
SoobCrazy SoobCrazy is offline
SVX n00b
Re: SVX on dyno
What brand of dyno was this test performed on?
Same question to you sicksubie...
Old 03-21-2016, 03:28 PM
bishop bishop is offline
Re: SVX on dyno
When I dynoed my stock svx way back when with 170k miles it did 180whp 185wtq. Dynojet dyno btw.
Old 03-22-2016, 07:01 AM
sicksubie's Avatar
Re: SVX on dyno
Mustang dyno for me... Which makes sense as my numbers give me about a 35% drivetrain loss and Bishop using a Dynojet experienced a 22% drivetrain loss. The average difference between Dynojet and Mustang dynos is in the range of 12% with Mustangs reading lower.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 11-28-2016, 01:37 AM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
Re: SVX on dyno
Wow, that is almost a 50% loss!
What is your mileage? Still driving on the Autotragic?
Sam
Old 11-28-2016, 04:37 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Re: SVX on dyno
So does that mean the gearbox is on the way out ???
Old 01-07-2017, 10:15 PM
GreenMarine's Avatar
GreenMarine GreenMarine is offline
From POST-***** to LURKER
Re: SVX on dyno
I've got video from my 5MT SVX on the dyno somewhere.... Let me see if I can find it... It was NEARLY 10 years ago so apoligies if I don't have it anymore... But I'll look
2020 Subaru Outback Touring - Wife's first Subaru
2005 Volvo V70R - 5-cylinder love! :Heart:
** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned
** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!!
** SOLD ** 1995 "Tree-Hugger Green" SVX L AWD(5 MT) --- "Gumby" 130K miles #399 in MY95, my original love...
Old 04-07-2017, 10:22 PM
Gamesy's Avatar
Re: SVX on dyno
i was 122awhp at 3800rpm
the svx is 230 crank at 5600 rpm
Old 07-12-2017, 10:44 AM
Nevin's Avatar
Nevin Nevin is offline
Re: SVX on dyno
Definitely sounds like a heartbreaker dyno for sure.
Dsport magazine did an issue a while back comparing different dynos with two cars to compare what the differences actually were.
Jesus is the remedy
2015 Expedition EL Ecoboost
