Where to buy?
So I have to replace my rear cross member differential bushings.
Will check out that link thanks Blacky Anyone got after market options Last edited by FlipC; 08-02-2013 at 10:40 AM. |
Re: Where to buy?
Are you going to DIY? You have to drop the Diff to install the OEM...
Cheers! Gordon 1997 Ebony #308 113k "The Black Diva"SOLD 1992 Black over Liquid Silver 152k SOLD 1992 Ebony 251k 444 SOLD 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
Re: Where to buy?
The bushings that connect the diff member to the rear sub frame are:item#5
41322AA010 Bush Diff Mt F 2@$38.98 ea. http://www.subaruparts.com/diag/?mod...ategory=201-A1 |
Re: Where to buy?
Yes DIY
Im in the middle os a tranny swap. Going to a Legacy 4:11 The OG ones were being held in with silicone. Pushed right out with my fingers. Thanks for the link Blacky. Least I know I can get the OEM ones. Anyone got after market options? Last edited by FlipC; 08-02-2013 at 10:46 AM. |
Re: Where to buy?
So been busy just getting a chance to get back to this.
It turns out that is not the part I need. Having looked at the parts catalog (wuala) neither the 92-94 nor the 94-97 list the parts Im in need of. The diagram doesn't show them. having looked via Google Image I haven't found a single picture either. So here are some pictures of what I need to replace. |
Re: Where to buy?
The parts you want are: 41322PA000 Bushing Assembly, Differential Mounting, Rear $36.72 each PART 41326A in the diagram [ MAIN ][ SVX ][ 1997 4WD ][ Engine Mount, Fuel, Exhaust and Engine Cooling ][ Differential Mounting ] .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 08-21-2013 at 05:18 PM. |
Re: Where to buy?
Sweet!
Thanks so much mate. Just noticed that little double dotted line. |
Re: Where to buy?
As I recall, these bushings are curiously omitted from the subaruparts.com parts diagram for 1992; you have to look at a later model year.
dcb |
Re: Where to buy?
Or you could grab some of these poly diff bushings.
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. |
