Where to buy?
So I have to replace my rear cross member differential bushings.
Will check out that link thanks Blacky Anyone got after market options |
Re: Where to buy?
Are you going to DIY? You have to drop the Diff to install the OEM...
Re: Where to buy?
The bushings that connect the diff member to the rear sub frame are:item#5
41322AA010 Bush Diff Mt F 2@$38.98 ea. http://www.subaruparts.com/diag/?mod...ategory=201-A1 |
Re: Where to buy?
Yes DIY
Im in the middle os a tranny swap. Going to a Legacy 4:11 The OG ones were being held in with silicone. Pushed right out with my fingers. Thanks for the link Blacky. Least I know I can get the OEM ones. Anyone got after market options? |
Re: Where to buy?
So been busy just getting a chance to get back to this.
It turns out that is not the part I need. Having looked at the parts catalog (wuala) neither the 92-94 nor the 94-97 list the parts Im in need of. The diagram doesn't show them. having looked via Google Image I haven't found a single picture either. So here are some pictures of what I need to replace. http://huntsvilleflatfour.com/images...ddMount-01.png http://huntsvilleflatfour.com/images...ushings-01.png http://huntsvilleflatfour.com/images...ushings-02.png |
Re: Where to buy?
The parts you want are: 41322PA000 Bushing Assembly, Differential Mounting, Rear $36.72 each http://www.subaruparts.com/subaru.diag/2A/i415A-1.gif PART 41326A in the diagram [ MAIN ][ SVX ][ 1997 4WD ][ Engine Mount, Fuel, Exhaust and Engine Cooling ][ Differential Mounting ] . |
Re: Where to buy?
Sweet!
Thanks so much mate. Just noticed that little double dotted line. |
Re: Where to buy?
As I recall, these bushings are curiously omitted from the subaruparts.com parts diagram for 1992; you have to look at a later model year.
dcb |
Re: Where to buy?
Or you could grab some of these poly diff bushings.
