Old 06-24-2012, 09:12 PM
kjoyes kjoyes is offline
Help me trouble shoot bad am/fm reception
I need help trouble shooting bad am/fm reception
i have a pioneer after market radio so i am only using the antenna to get reception.
i get one station. that is unexceptable....
Old 06-24-2012, 10:12 PM
Re: Help me trouble shoot bad am/fm reception
Are you sure you plugged it into the antenna, and not the defroster? Try plugging it into the other antenna plug, and double check that it's plugged in nice and tight.
Old 06-25-2012, 06:45 PM
hi everything is pluged in i have the 18inch extention pluged from the back of headunit to the black female connector that runs to a plug that plugs into the antenna assembly.
Old 06-25-2012, 10:39 PM
There are 2 plugs back there that your extension could have found its way toward. Are you sure it's the right one? If not, try the other one. It's back there somewhere.
Old 06-28-2012, 11:14 AM
yes i am sure i am not in the small gray wire antenna that goes to the rear defroster that has a male plug
i have a male to male extention so i wont even go in that plug.
Old 06-28-2012, 12:03 PM
LastSVXintheChi's Avatar
LastSVXintheChi LastSVXintheChi is offline
Send a message via AIM to LastSVXintheChi
my radio get all fuzzy when i turn the rear defrost on...does that happen to anyone else?
Jared
1992 dark teal SVX LS
Old 10-17-2012, 01:54 AM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
i have a pioneer after market radio ...
That is the wrong one. The factory antenna cable with the male Motorola plug is the one that goes to the SVX's motorized antenna. You need an 18" extension cable (female to male). Technically, your male to male cable is a gender changer.
See picture here.
Here's how I remember which antenna lead goes where: Imagine if the car's antenna cables could reach the rear of your aftermarket head unit. The correct one that you should use is the one that you could plug directly into the Motorola socket on the back of the HU (if it would reach).
Contrary to what I wrote in my SVX Audio guide (and need to fix), the second antenna (on the rear glass) is a separate section of foil -- it's not part of the rear defogger. You can get noise from the defogger (often caused by bad ground leads back there), but that's due to the proximity, not because the antenna is using the same foil.
After switching to the motorized antenna, if you still have poor reception, you may need to clean the mast and contacts. See this thread:
Does the mast antenna ever go bad? Reception problems.
David C.
1996 Laguna Blue Pearl SVX L AWD
See my home page for SVX radio install/removal instructions and wiring harnesses
