Old 03-13-2011, 10:53 PM
Jay Wrix Jay Wrix is offline
Mystery Brake Leak, Help!
so, I once again have the dreaded dead pedal. and Ive lost a bottle of fluid, over the last 1,000 miles or so, and I can bleed the brakes, get a pretty solid pedal, and then, like someone pulled a petcock, I check and im out of brake fluid, and light comes on, this time ive really had enough.
I cannot find a single drop of brake fluid from the rubber hoses, to the calipers. and all engine compartment lines. The calipers check out good, and im not leaving any fluid where I park, other then the oil my eg33 likes spewing.
I cannot find the lines that run around ( in??) the car? a diagram would be really killer! or someone with a similar experience,
I even sat in the garage and pumped it for an hour, and got NOWHERE.
help please!
Old 03-13-2011, 11:08 PM
Re: Mystery Brake Leak, Help!
The brake lines to the rear brakes run through the insides of the car. It's possible for a leak to hide along those somewhere. Start looking from the back forward since those areas are more prone to rusting. They go through the inside of the car, under the carpet/door sill area on either side, then at some point they go back outside of the car toward the rubber lines. I remember some lines going through floor under the rear seat, but I forget if those were fuel or brake lines or both.
Old 03-14-2011, 12:33 AM
Old Fogey
All that fluid has to be going somewhere! That stuff eats paint and lots of other stuff for lunch, so I'd pop those door sill covers and prepare to suck it all out with a baster or such. Good luck, and let us know what you find.
Glenn
Old 03-14-2011, 05:28 AM
michael's Avatar
michael michael is offline
What Potholes ???
IIRC Mike621???(sp) had a master cylinder leak at the firewall in the inside. If you are loosing that much fluid it should show up somewhere. Are you noticing any unusual amounts of exhaust smoke?
Wanted: Steering Wheel
Old 03-14-2011, 11:08 AM
gbianchi gbianchi is offline
I would add that if its leaking inside the car you should be smelling it, that does not sound like any fun, good luck with the fix...............G
I thimk ther4 I an, what? huh!
03 Baja. 05 Baja turbo
92legacywagon"snow"
94legacywagon"whinny"
84Brat"huey"
92svx"samantha".pearl
92svx"sabastian"4.44 silver
92svx"sabrina".ebony
05legacy gt limited "Moon" blue.
06 Subaru legacy gt limited.
Old 03-28-2011, 05:59 PM
found some fluid seeping between the master cylinder and down onto the exhaust,
Finally getting around to replacing it in the next few minutes, fun fun fun.
Old 03-28-2011, 08:48 PM
Yes.
Check your master cylinder reservoir.
The black gasket where it meets the reservoir was leaking on my car, albeit slowly.
Also check under the center rear of your car for fluid for any additional leaks, as the rear hard lines do go out on our cars and I had to replace them on mine, too.
Old 03-28-2011, 09:58 PM
I checked before my parts car was taken away, the passenger side is brake lines, the driver's side is fuel lines. (In case anyone's searching years later or something).
Old 03-28-2011, 11:50 PM
icing death, thanks,
suspision of master cylinder was correct, all the paint came off my brake booster, go figure. it was loaded up with crud too, bench bled the master, dropped her in, went to bleed the wheel cylinders, and flush out the old fluid.... and well, she didnt exactly like the high pressure.
well, I hear a hissing after I shut the bleeder, figuring the evening was getting to me, after watching the wings game and a late start, and suddenly a crack and torrent of brake fluid rushes from the hardline inside of the subframe railing directly above the fuel filler tube.... I need this thing to work to travel 600 miles this week!
Where can I get hardlines!? can i use one of those patch things??
Old 03-29-2011, 07:01 AM
I replaced my rear hardlines when my rear subframe and differential was out. They are fairly inexpensive from subaru and the junction where they connect is on the left side of the car in front of the wheel adjacent to the subframe bracket.
If you have a flare tool, you may be able to patch it if you can see the actual leak, but I am unsure of the success in "patching" lines and would avoid addressing the problem in that manner unless it was an emergency situation only. (Even in that case, the only safe way to fix a corroded brake line is to replace it, IMHO)
Old 03-29-2011, 09:16 AM
yea, id like to drop the subframe to doit thats just rather impossible for me., can the line be weaseled out with the subframe in?
