View Poll Results: Select the choice(s) which best matches your situation(s) | |||
1992, Original tranny never failed, Car never modified |
10 | 11.49% |
1992, Original tranny never failed, Car modified for higher HP |
2 | 2.30% |
1992, Original tranny failed, Car never modified |
39 | 44.83% |
1992, Original tranny failed, Car modified for high HP |
7 | 8.05% |
1993, Original tranny never failed, Car never modified |
4 | 4.60% |
1993, Original tranny never failed, Car modified for higher HP |
0 | 0% |
1993, Original tranny failed, Car never modified |
4 | 4.60% |
1993, Original tranny failed, Car modified for high HP |
1 | 1.15% |
1994, Original tranny never failed, Car never modified |
8 | 9.20% |
1994, Original tranny never failed, Car modified for higher HP |
0 | 0% |
1994, Original tranny failed, Car never modified |
7 | 8.05% |
1994, Original tranny failed, Car modified for high HP |
0 | 0% |
1995, Original tranny never failed, Car never modified |
3 | 3.45% |
1995, Original tranny never failed, Car modified for higher HP |
1 | 1.15% |
1995, Original tranny failed, Car never modified |
2 | 2.30% |
1995, Original tranny failed, Car modified for high HP |
0 | 0% |
1996, Original tranny never failed, Car never modified |
6 | 6.90% |
1996, Original tranny never failed, Car modified for higher HP |
0 | 0% |
1996, Original tranny failed, Car never modified |
5 | 5.75% |
1996, Original tranny failed, Car modified for high HP |
1 | 1.15% |
1997, Original tranny never failed, Car never modified |
8 | 9.20% |
1997, Original tranny never failed, Car modified for higher HP |
1 | 1.15% |
1997, Original tranny failed, Car never modified |
2 | 2.30% |
1997, Original tranny failed, Car modified for high HP |
0 | 0% |
Multiple Choice Poll. Voters: 87. You may not vote on this poll |
Thread Tools | Display Modes |
The failed transmission poll
Not sure if this was ever done or if I will do it right but I will give it a shot. The idea here is to get an idea of the rate of failures for different model year cars under various conditions.
Re: The failed transmission poll
Good idea.
How about those of us who have the original tranny, never failed, but are starting to suspect a failure in the not-so-distant future? ![]()
Jon 1997 SVX LSi Bordeaux Pearl 1995 SVX L AWD Polo Green - 277k miles 1986 Pontiac Fiero 3.4L Twin Dual Cam V6 |
Mine is a 1994 with 187,000 kms and the tranny is just starting to slip between 1st and 2nd. I'm hopin it's a solenoid problem but have not checked it out yet.
94 SVX LSI 2001 LegacyGT (daughter's ride now) 2005 Legacy outback XT (wife's car) all stock and likely staying that way for now 1981 Datsun 280zxturbo summer toy |
holy poll options batman!
92 silver-original failed 60-70k
Subaru reman failed at 103k 92 NJ claret-don't know when original failed bought with failed subaru reman with 118k 94 laguna FWD-original trans good, failed diff with 93k-was abused for 2 months by stupid kid 94 pearlie fwd-160k original trans as far as i know 92 FL claret- 143k-probably subaru reman or other rebuild 92 ebony parts car-101k, had subaru reman in it that ended up being good 92 pearl parts car-bought without drivetrain, had receipt for Subaru reman at 78k, previous owner that parted out drivetrain said trans was still good with 145k on car 92 pearlie i worked on, had 145k on it, had a reman in it but can't say the mileage that was on it. 92 ebony I'm going to be working on, 190k and has Subaru reman that is very strong in it-not sure if its the first or second reman though... IDK how i'd put all these options into the poll, but there's the info... |
As far as I know, my 94 has the original trans in it and is at 192k miles.
However, the differentials had issues and were attended to as necessary.
1994 subaru svx le 112k |
That's a lot of mileage and you don't know if it is failing so I would call that a non-fail...for now. I think I will leave this poll open for a long time to let people go in and change their choices as necessary.
If you are certain it is failing, you can list it as a fail. Otherwise, assume the best case scenario for now.
Anyone that never responded to this, here is your chance. As of right now, here are the statistics:
Tranny failure rate = 76.6% Wow. Failure rate by year: 1992 = 83.3% 1993 = 100% 1994 = 37.5% 1995 = 25% 1996 = 66.6% 1997 = 25% 1992 isn't a surprise but 1993 and 1996 seem like anomalies. The failure rate for modified or hard driven cars is 66.6% so that doesn't seem to be a major factor. Mike's new TCU code keeps the line pressure high at low throttle and Mike has said that he believes this is a major factor in tranny failure. Clearly, the modifications made by Subaru also reduced the failure rate. This implies the known flaws with ATF flow and clutch material were a factor. I think, together, TCU programming and original tranny flaws are a really bad combination. Here is a theory. When someone is stopped or cruising at light throttle, the line pressure is low due to the original TCU programming. If one then stomps on the gas, the engine soon delivers a ton of torque to the tranny. If that torque arrives before the line pressure rises in response to the TCU asking for more line pressure, the weak clutch material, high torque and low line pressure would result in a slip which would damage the tranny. If done many times, the tranny starts slipping worse and worse and the ATF heats up more and more and you have a downward spiral. The poor ATF flow may also cause the line pressure to rise more slowly when the TCU signals for higher pressure. This could be the main cause of or, at least, add to the delay. Just a theory. But, if true, Mike's TCU changes plus his valve body modifications would both be a big help in addition to what Subaru already did in the later models.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 05-05-2011 at 10:51 AM. |
Lee
SVXx2 92 SVX LS-L Silver 92 SVX LS-L Burgundy (structurally challenged with 2792 miles) 96 SVX LSi Red 92 SVX LS Pearl (Parts) 01 F150 4X4 Red (+6 with other members of the family) FREEDOM IS NOT FREE |
I agree, way too few entries in the poll. Hopefully this will bump it up so that more people will answer.
That's why I called it an anomaly. The sample size is too small at this point. It looks like 1994-1997 have a failure rate of around 40%. It is probably even lower for 1995-1997 as, I believe, all of the Subaru changes were in place by around mid-1994. But you can see the issues with 1992-1993 models pretty clearly.
You also have to take into account the fact hat the 1992 is about 33 percent older than the 1997 models. Thats quite a large difference. Much more time for miles to add up and tranny parts to wear. I would take this poll with a grain of salt. I believe people should still post their personal experiences and vote on the poll but it is much too early to make any kind of conclusions outside of the obvious, already known facts.
I need to add a few but I don't remember which ones I put in already... basically, with the SVXi that I've been in, and have, or have worked on, I'll list here in addition to the ones I listed earlier
92 silver- 2 dead transmissions by 103k miles 92 ebony parts car-pulled reman out of it, sold to fellow member and was told it was working but hasn't been driven much at all due to other circumstances, had 101k miles 94 fwd Laguna-trans was good but failed front diff, figures, it is a fwd, 93k when I got it, just turned 105k this week 92 Claret-2 transmission failures by 118k miles 94 FWD pearlie-original trans as far as I know, 160k miles(ish) 92 pearl parts car-paperwork of original trans dying around 76k, and as far as I know still was good (bought car without any drivetrain left 92 FL claret-143k, bad transfer clutch, had a rebuild in it 94 emerald-unknown, was wrecked badly, picked up with no drivetrain 97 ebony-110k miles, trans was replaced around 108k, unknown if trans was dead or just had transfer clutch binding 92 pearl-unknown, 142k miles, no trans in car so assumed old one was bad, hasn't been on the road since April of 02 as I found out 95 emerald-108k, has bad trans, I assume original 94 emerald fwd-130k miles, assume original trans 95 polo LSi-125k miles, bad trans and assume it is the original 92 pearl-111k, bad trans, haven't been able to find out if its original or rebuild, previous owner bought car around 93k miles last 2 in my signature I have no clue ones I've worked on 94 Emerald AWD-failed trans, original around 103k 92 pearl-front diff failed, 145k on body, had reman trans Can't remember the others, so I'll add these newer ones to your poll... can you tell I'm a little bored tonight? ![]() |
