Old 07-02-2010, 09:24 AM
Ricter Ricter is offline
Front diff failure/4.44 sanity check
So after noticing the dreaded 'baseball card in the spokes' sound from my 92 AWD the other day I dropped it off at the local Subaru specialist for verification that the front diff was the culprit. Not surprisingly it is.
So now I'm looking at options and would like some feedback here. My transmission, minus some minor slippage when cold, is in good shape.
Should I just have the diff replaced and call it a day?
The tech at the shop mentioned upgrading to a diff/trans from late 90s model outback. After looking around here I'm guessing that would be what equates to the 4.44 swap. Am I correct in that assumption? If that's the case can someone tell me what all is involved in that swap so I can have a sanity check on what they tell me? Does that include the entire front trans/diff assembly and the rear diff? Just a portion of that, or all that plus something more?
Ideally I'd like to have manual swap done, but I simply don't have the funds for that at the moment. How much does a manual swap usually run in cost vs a 4.44 swap?
Thanks.
Old 07-02-2010, 10:10 AM
Wikedjuggalo's Avatar
Rebuilding
Re: Front diff failure/4.44 sanity check
Thanks.
The 4.44 should be cheaper but the 5spd is funner.. ask me how I know! But you can get a used 4.44 cheaper than what sourcing a 5spd and all the parts would be. Unless you are up to making the shift linkage and modifying the drive shaft. Also the peddles but its worth it.
But I paid 1500 for trans and parts (pretty much a once in a lifetime deal) and another 1500 or so in Labor.
Old 07-02-2010, 04:33 PM
Blacky Blacky is online now
The front diff/trans is swapped as a unit. You use the limited slip parts of the SVX diff with the gears/case of the Outback, minor grinding of case modification needed. You also swap the speed sensor from the SVX trans (3 wire) to the Outback trans (2 wire).
Old 07-02-2010, 07:11 PM
Thanks.
Check out the link in my signature.
Old 07-02-2010, 07:33 PM
I've got signatures turned off. Let me go through my settings and figure out how to make them viewable again.
Edit: Found it. Thanks! I wonder what else I've been missing by not viewing sigs?
Old 07-02-2010, 07:56 PM
gbianchi gbianchi is offline
The 444 swap file from svxfiles is dead on! No guess work involved, get the parts, get going and before you know it your 4.44ing around in an svx444=fun! I did it and its very cool, its strange having 2 svx's one stock and one 4.44, stock ones are more relaxing, while 4.44s are eager to go? Good day to all......................G
I thimk ther4 I an, what? huh!
03 Baja. 05 Baja turbo
92legacywagon"snow"
94legacywagon"whinny"
84Brat"huey"
92svx"samantha".pearl
92svx"sabastian"4.44 silver
92svx"sabrina".ebony
05legacy gt limited "Moon" blue.
06 Subaru legacy gt limited.
Old 07-02-2010, 08:11 PM
The write up does seem to be pretty detailed and makes this thing seem a lot more feasible.
Next question: Does someone have a complete parts list for this swap? With a write up like this I may attempt this myself.
Old 07-02-2010, 08:30 PM
There is no parts list. You need the tranny and rear diff from the donor car thats it. Everything else to do is in the write-up.
Old 07-02-2010, 08:38 PM
You think that's interesting, how about a stock geared, 4.44 geared, and a stock fwd... each one feels very different from each other.
As blacky said, there is not parts list, get a trans and rear diff from a 96-98.5 outback or other legacy models equipped with the 2.5. Then its just swapping a couple things from the stock trans and rear diff and some modification, its all in the write up and is very straight forward.
Old 07-02-2010, 11:28 PM
SomethingElse's Avatar
word words wording
if you wanna stick with stock gearing send me a pm i have a complete front diff ready to go.
Eric
Old 07-03-2010, 05:35 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
How about going from stock, to 4.44 to 3.90 MT, all in the same car?
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
