Accepted to grad school! Summer plans
So, there's now a week left in my last semester before graduating with a bachelors in biomedical sciences. One final exam and one research paper, and I'm done. Well sort of. I just found out I got officially accepted to a graduate program about a week ago.
![]() So, seeing as how the next 4 years are going to busy with research, I've put together a little list of all of the car projects I want to get finished with over the summer: SVX: 6-speed swap -clutch/flywheel/pressure plate have been resurfaced. found out it's a ~2600 lb pressure plate and got a stage 1 clutch. poly bushings konis/dayle's springs -changed my mind, G/C coilovers instead, which have also arrived brake fluid/pads - done (Redstuff pads f/r and superblue) plugs stebro exhaust wheel bearings maybe some interior work apkarian's LED tails The majority of these parts are sitting in my garage, ready to go as soon as I get a chance. Also be helping to get my brother's 240 put back together now that the motor's built and together: 240: put engine back in -done change ecu to SR20DE ecu -wiring harness about halfway hooked up wire-in boost controller and ecu piggyback trunk-mounted battery -all the wiring is done, gotta mount the battery itself Update: We just discovered the hood doesn't shut all the way. Gotta figure something out, but most likely it'll end up looking like tom's beast. What do y'all think? Any other miscellaneous maintenance I should do while I have the car all apart? I need to order some valve cover gaskets and cam seals to do those as well, anything else I should reseal while I'm at it? I could also really use some general advice on the 6-speed swap. I'll post pics of all the parts I've got for it later.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() Last edited by icingdeath88; 07-04-2010 at 09:52 PM. |
Re: Accepted to grad school! Summer plans
You are a crazy man.
94 SVX LSI 2001 LegacyGT (daughter's ride now) 2005 Legacy outback XT (wife's car) all stock and likely staying that way for now 1981 Datsun 280zxturbo summer toy |
check the rear trailing arm bushings and rear diff bushings. You will have it apart anyway so may as well replace those too.
My rear diff bushings were all but destroyed! I'll second that!
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
![]() ![]() ![]() ![]() ![]() Stock sti shiftknob w/cobb shortshifter: ![]() The strongflex bushings: ![]() ![]() ![]() The car it's all going into: ![]()
Danny 1994 Silver SVX in hybernation, awaiting for the monsterous awakening (Lebanon) ![]() 1967 Mercedes-Benz 250SL Euro Specs, Hard/Softtop, White/Red. Under Complete Restoration ![]() 2013 Mercedes-Benz SL350 Euro Specs, White/Red. Mint... Another step into SL Collection. ![]() |
