OK so know that I have just spent $1k on tires (Falken ZE912) - my cruise control is now NOT working....
Push swich in - hear relay click on (under the glove box area) - but nothing happens. Is it controlled by Vacuum - if so I may have a leak somewhere not allowing the thing to function, any help would be great... Steve (1 OF 1) - with only 141,000kms for 1995 |
Re: Cruise control - not working
Check this hose
Michael - thanks for the quick response, will do that tonight.
Steve |
OK checked the hose - all fine, no cracks.....so where to now??
Are you sure the click was a relay and not the switch itself? if it was the switch check the fuse. Does your speedometer work?
Switch working & so is the relay under the dash..........as a side issue what is the "things" at each end of the cruse control hose.
1 is under the fuse box 2 is linked the throttle linkage. |
