Old 09-25-2008, 03:52 PM
help on fixing glass molding..
I have a gash/slit on the lower portion of the fixed glass, hard to explain, so i attached a pic...circled in red...
anyone know the removal and installation procedure? thanks in advance, chris
Old 09-25-2008, 04:15 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: help on fixing glass molding..
It is glued on the inside of the car to the metal frame. I would take a heat gun to it and roll the edge towards the outside, then remove it, and reapply weatherstrip adheasive to the new moulding and use several c-clamps to hold the new rubber tight in place against the frame and let it set up for several hours.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 09-25-2008, 10:09 PM
plantchick's Avatar
plantchick plantchick is offline
Mechanical 'L' plater ahead
Hi Chris, hope these help. The last three are most relevant & one of them describe the heatgun rolling thing redlightning recommended - the first couple give an overview of the whole door/window mechanisms and tolerances.
Windscreen place told me to use either 3M weatherstrip adhesives &/or 3M quick-fix (for smaller tears).
Now if only they could have told me why the lower front part of the upper glass seems to have a foam strip that joins to the normal weatherstrip and how to fix or recondition that.
Tania.
1992 Onyx SVX 184,500kms
Now with new and improved no leak steering!
No plants = no life on earth - so go forth and plant green things!
