auto-x alignments.....
I would like to know what alignment specs people are running for racing. I would like to know the camber/caster ##'s as well as what your suspension height is. I was not able to get an alignment before the auto-x on saturday after installing my coilovers this past week. I was actually running a very small degree of positive camber in the rear. That really hurt me.
Here was what I was thinking... Get it aligned to stock specs at my daily driving height and then at the race lower it slightly giving me negative camber.... Input? Advice? P.S. looking for advice on tire options as well
Re: auto-x alignments.....
Stock specs are quite conservative, only -0.7 or so in the front. Dropping the car an inch isn't going to give you much more that that, probably not past -1.0. Most of the local Subie Auto-xers run at least -2.0 at all four corners here.
Now if you had camber plates in the front it would be a different matter.... *continues thinking about STi coilovers....*
Bobby,
Stock camber bolts (front only ) will give you a max of ~-1.8 degrees of camber, so use all of it. You'll need to get aftermarket camber bolts for the rear (do a search for the number) and then they'll give you ~-1.5 degrees for the back. Zero degrees of toe works fine (you can play a little here, but I run 0). Stock caster works fine. -Bill p.s. yes, camber/caster plates are nice
Can I max out my fronts on my own? If so, any tips on an easy way of doing it?
You could get a camber guage to see what you're setting them to. Someone at Auto-x likely has one.
Alignment today... -1.8 in the front, -2 in the rear, 0 toe, stock caster
