i've been checking out some of the how-to documents in the forum and came across the throttle body bypass..the mod seems simple enough..but i was just wondering what exactly does it do.??//?
1992 Subaru SVX LS~L Ebony Pearl 1992 Dodge Stealth R/T Firestorm Red 1992 Subaru SVX LS~L Pearl White 1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD 2007 Subaru Legacy Spec B. Diamond Grey Metallic |
Coolant is routed through the throttle body as a precaution for colder climates, so they do not freeze up due to huge volumes of icy air rushing through it.
The bypass "mod" reroutes this coolant, or "bypasses" the TB and keeps it at a slightly cooler temp so the incoming air does not heat up quite as quickly or as much.
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. ![]() |
thanks for the info
i was really hoping that i wouldn't get a "do a search and you'll find out" kind of reply...though i wouldn't be surprised if i did anyways. ![]()
Seeing where you live, Gates of Hell, you should be able to use the mod year round.
Those of us living up north can only use it as a summer mod. Some members have installed an inline valve to make the seasonal changeover even easier. Yesterday on my drive to work I saw 2 degrees, this morning it was 'much' warmer, 7 degrees . . .
Dan Pentiums - Melt in your PC, not in your hand! Project - '92 Claret - Purchased May '06, 99,XXX Miles. Includes two bad engines and one bad tranny, cracked windshield, otherwise mostly complete. His - '92 Ebony Pearl - Purchased Dec '05, 134,687 Miles. Parked, TC Seal(?) is leaking.Daily driver - 140,500 and climbing. Hers - '92 Teal - Purchased Aug '05, 129,050 Miles. Daily driver - 160,000 and climbing. Mods: PWR Radiator! Problems: Antenna doesn't work - Bought a 'new' one - Too cold to install . . . OK, it's warmer but I have other projects too! ![]() Ticking from front of engine, passenger side - Stuck lifter? |
Middle of December for cryin out loud. Winter solstice is around the corner and were seeing record highs.
My Nokian Studded Hakkapeliitta 2's are earning their keep, it's fun passing the idiots at the side of the road chaining up or stuck in ditches!
![]() I wish it would warm up for a few days, I have a pile of logs to cut up for fire wood, but they're frozen together . . . Dan |
well...it's not that really live in the gates of hell.....i really think this is the first level of Hell...kind of explains how ****ty life is....my actually home is the 7th layer of Hell.....but i have to die first in order to get there...
///////////we live in different realities ![]() .........now you guys are probably looking to kill me and getting a parts car
