Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Suspension
Old 08-06-2005, 11:07 AM
Fifteen minute, $15.00 rear suspension mod.
I wanted to reduce the amount of play in the rear crossmember, without the noise or squeeking of hard polyurethane bushings.
In Advance Auto Parts "HELP" section, I came across these steering coupling discs, part # 31000.
They are just over 3" in diameter, and a little over 1/4" thick when compressed. Multiple layers of rubber and fabric and very durable.
They are perfect to use as shims in between the factory bushings, and the 3" in diameter rubber backed washer Subaru calls the "stopper diff mtg.
Jack up the car safely, and remove the two 17mm nuts that hold the stoppers in place.
Remove the washers.
Install the rubber rings, and the stoppers, and the nuts.
Tighten.
Lower the car and you are done.
Tom.
Old 08-06-2005, 11:29 AM
Way to steal my idea!!! Actually I am using something else and it will be firmer and cheaper... Anyone want to play some hockey???
Old 08-06-2005, 11:54 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Thumbs up
Nice. I'm going to get this done! Very straight-forward and elegant Tom!
-Chike
2006 Steel Gray WRX TR (sold)
Old 08-06-2005, 12:17 PM
Sorry, Lumpy.
Old 08-11-2005, 04:46 AM
LarryIII LarryIII is offline
Tom,
I have some official NHL pucks, autographed by a certain Flyer goalie. I wonder if this mod will make the SVX play better on the ice?
Old 08-11-2005, 05:18 AM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Originally Posted by LarryIII
Tom,
Don't do it Larry... You're car will run good all year and then stop running completely next May
Old 08-21-2005, 04:05 PM
Bwana's Avatar
Bwana Bwana is offline
*Special* Member
Send a message via AIM to Bwana
Just to make sure...the suspension has to be un-loaded to do this, right? I've got a nice set of ramps sitting in the garage, and i havent found a reason to use them yet.
[/COLOR][/COLOR]-Scott My Locker
2014 Grey Ford Fusion 2.0 EcoBoost Bought: 12-5-14
2005 Silver Legacy GT Ltd 5mt. Bought: 3-3-07 Sold: 12-5-14
1996 Brilliant Red L (AWD). Bought: 6-14-04 - Sold: 3-3-07 - 15.370 @ 89.65
1992 Claret/black LS #4086 (GF's). Bought: 6-30-04 - Sold: 7-29-07
1994 Pearl White LSi Bought: 2001? Sold: 2004?
Old 08-21-2005, 04:23 PM
The ramps will do fine.
As long as you can reach it, and break the nuts loose you can do it.
Old 08-06-2005, 12:22 PM
Hey!! I didn't get personal about it.....
But Maybe I just have to
embarassing picture insert here:
Old 08-06-2005, 12:26 PM
So sorry, Tom.
Hows your forehead?
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Tom,
Awesome mod! Wonder who's car that is...
-Bill (Sunday can't come soon enough....)
Retired NASA Rocket Scientist
Center Network Member #989
Old 08-06-2005, 12:28 PM
It's MINE! MINE MINE MINE I tell you!
Old 08-06-2005, 12:30 PM
It's ok it is all in good fun.. Anyway what I meant by my hockey comment is that I will be using a hockey puck for my bushings. I will cut them to my spec and add them to each side of the subframe bushings. I have explained it in my Projects at Hand thread
Old 08-06-2005, 12:34 PM
Cool. I have not seen that thread yet. I hope it works out.
BTW, Bill posession is 9/10ths of the law.
j/k
Old 08-06-2005, 06:41 PM
mbtoloczko's Avatar
sans SVX
Did it have any effect on handling or on driveline bounciness?
Mychailo
Visit my locker
