Old 05-04-2003, 10:51 AM
billgiller
How can I keep cruise control button on dash on all the time?
My cruise control switch is finicky and I'd just like to keep it on all the time, so I can use it whenever I need without jiggling the damn switch til it lights. Help!
9
Old 05-04-2003, 11:06 AM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
There is no way to get it on all the time that I am aware of...
However, you seem to have some vaccume issue. Check the vaccume hose that leads into the Throttle body and make sure that it is not loose.
L
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 05-04-2003, 01:55 PM
SVX JAZZ's Avatar
SVX JAZZ SVX JAZZ is offline
Tired
Try hitting it real quick. Mine works each time when I do that. If I don't hit it real quick the button does not hold. Another goofy thing it's done for years.
Paul
1992 LSl (Black Mica)
1965 Mustang G.T. Fastback
1990 Mustang G.T. Convertible
1986 1/2 Nissan 4x4
2004 Vovlo XC70 (wife's)
Wonderful Wife
Wonderful Son
2 Cats
Incredibly blessed!
Old 05-04-2003, 02:18 PM
lee lee is offline
I don't know and have not thought about the consequences, but perhaps you can find the switch wires and jump across them. see attached diagrams (sorry for the negative images, haven't figured out that adobe program yet).
Old 05-05-2003, 08:57 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Send a message via AIM to mohrds Send a message via Yahoo to mohrds
Unhappy
You can't jump them because it is a momentary switch.
You could replace the switch with a relay pulse after the car starts, but that's about it.
You could also tap a new momentary switch into the harness to have a reliable push button for turning the cruise on.
Doug
1992 LS Touring (6/91) - Currently undergoing a five speed swap
Black over Claret with spoiler; 235,000 miles; Mods: 2002 Legacy 5 speed, ACT Pressure Plate, Excedy Clutch, Short Throw Shifter, Aussie Powerchip
Black over Claret with 2.5" setback spoiler; 202,000 miles; Mods: B&M Cooler
1994 LSi (4/93)
Bordeaux Pearl; 198,000 miles; Mods: Weight reduction.
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Sola lingua bona est lingua mortua.
Old 05-07-2003, 07:10 PM
gcookaustin
Maybe wedge something between the button and the side, such that the button is always held down. Don't have my car here so can't try right now,
Old 05-08-2003, 08:17 PM
gl1674 gl1674 is offline
The problem is most likely to the oxidation of relay contacts (cruise control has 2 relays, one is activated when the yellow light is on, the other is when it is actually working). Relay contacts are the place to jump wires, but I'm not sure whether the cruise control computer will like it. The relays and the controlling unit are behind the glove compartment in dashboard.
Old 05-09-2003, 05:38 AM
I've always wanted mine to stay on all the time too.
The cruise button in the XT6 does stay on all the time unless I turn it off, don't see why it would hurt the cruise control unit, as long as it only had power when the car was running.
It'd be the same as reaching up and turning it on as soon as you started the engine.
Old 05-09-2003, 05:49 AM
Paisan Paisan is offline
Send a message via AIM to Paisan Send a message via Yahoo to Paisan
Try spraying the switch with contact cleaner. I know if I don't hit mine for a week or 2 it takes a few tries to get it working. If I turng it on at least 1x a week, it works fine.
-mike
'14 Touareg TDi | '04 Nissan Armada LE | '14 BRZ
http://AZPInstalls.com
Old 05-09-2003, 08:42 PM
gcookaustin
I've found that if you do hold the switch in while the car is turned to the "ON" position then it does light up, and stays lit while starting the car. I think I will wedge a small piece of plastic in there to hold the switch in.
