SVX difficult to start
Well, after hitting a kangaroo in May, I finally have my SVX back from the smash repairers and looking schmick. (I can thoroughly recommend Randall's at Maitland for any panel work - did a great job and took an interest in the car). Worked fine when I got it back, but now it has suddenly become hard to start - it takes about 6 tries to start, stutters and shakes and once it finally kicks over, the red engine light stays on, although runs fine once warmed up. Starting from warm is also no problem, just when cold. It is NOT a battery problem. My uneducated guess is an O2 sensor, but could it be a Knock Sensor (not sure of the difference)? And, is ebay a reliable source to purchase them from?
Any feedback would be great - thanks! |
Re: SVX difficult to start
Could be a temp sensor, have you checked for engine codes?
The car looks sweeet! Did they paint the whole thing?
It's not a knock sensor or O2 sensor problem. My first guess was temp sensor also. Did they do any mechanical repair? |
^this ....
Oxygen sensors are not used as an input to the ECU until the engine has reached normal operating temperature - it can't be that.
Knock sensors are not used as an input to the ECU during start and idle - it can't be that either. My guess would also be the Coolant Temperature Sensor, as the way in which the engine is behaving looks as if it is not getting the required cold start enrichment. It could also be the primary Crank Angle Sensor - from what I understand, the engine will not start or run if this sensor is malfunctioning. Jason.
1992 Charcoal Grey SVX - 165,000km 1992 Ruby Red SVX - 165,000km ....now with sequential VIN numbers! 1986 Holden (Isuzu) Piazza Turbo - 225,000km 1993 Mercedes W140 S500 Coupe - 153,000km 1990 Mercedes W124 300D - 313,000km EG33 + 4EAT + VTD AWD = SVX |
Check the code.
Thanks for all the tips - I will get the codes checked as soon as possible .....
In response to a few earlier questions, only the front half of the car was resprayed / blended, and no, there were no mechanical repairs necessary at the time. Cheers! Grant |
