Powder coated goodness! teaser pics
Here are a few teaser caliper pics from Harry's SVX; I just got them back from the powder coater. The pics are a bit dark as I didn't use a flash and the kitchen is dark. I'll be doing the assembly work this weekend and will document the rebuild procedure for a DIY. The next time I do a set, I will take pics during disassembly to complete the DIY.
Anyway, here they are (minus the hardware and all moving parts). |
Re: Powder coated goodness! teaser pics
mmm...goodness. Do you have to scrape the powder coating out of the slides/cylinder bores?
No scraping necessary - The powder coater plugs all of the threaded holes and the caliper bores. Sometimes he get a bit of powder leakage, but it's thin and pretty easy to remove.
Ah, makes sense. I guess the angle of the pictures just made it look like the bores had been coated.
Another teaser!
Caliper rebuild In Process. |
did you check the depth of the threads on the bracket for the bolt that locks the caliper in at the bottom (it's the one that only needs ~25 ft-lbs of torque)? I found that the PO of my Pearlie had helicoiled the hole, which, of course, came out while I was re-doing the brakes. OT sent me another bracket which ended up having a similar problem (no helicoil, just only had 3 threads of engagement) and then YT sent me a bracket that did the trick.
-Bill
[QUOTE=gsodonis;593296]Another teaser!
Caliper rebuild In Process. Looking good, Gads!!!!! Harry
newsvx 1992 SVX LSL, #1215 1997 SVX LSi, #370 "I live with fear every day. Sometimes she lets me go racing." "Getting Older and Slower" Locker: http://www.subaru-svx.net/photos/user.php?newsvx |
PS Part numbers would be great too.
Further teasers!
Front Calipers are finished! DIY is in process - a proper DIY takes about 4X - 5X as long as the actual job itself. First, the pretty pistons with the rust inhibiting coating on the inner bores New piston sealing rings on their way home Piston and boot on their way home New brake bleeder goodness (wearing a proper hat) The finished beuty Last edited by gsodonis; 04-05-2009 at 08:31 PM. |
WOW, they look good!!!! Can't wait to get them, Gads!!
Thanks, Harry
Ye Gads (sorry for the pun), They look great!! Can't wait to see the finished product!!!!!
Harry Quote:
