Momo NonAirBag Steering wheel Install
Ok had someone ask about this and figured I would post it so if others are interested.
I got this idea from Silver92Mike, I am not sure if he has an account here but here is his thread on the other forum http://svxworldforums.com/forum15/3102.html He went a different way then I did, a better way as he keeps cruise control but he bought a jdm legacy hub adapter with cruise in it, a factory unit from japan. Since I could not find, nor afford the jdm adapter I bought MOMO SUBARU WRX & STi Models Steering Wheel Hub Adapter Kit (7310) I then took off the wheel and pulled the clockspring, I had to cut all the cruise control and airbag wires off the top side of it and only the horn wire is still on it, then put it back on and the hub adapter on connected the horn button and put the wheel on. Now that takes care of the actual wheel and horn but I was left with the airbag system light on, I read you could pull the fuse but wanted to see if I could fool the computer into thinking it was still there. I measured the ohms at the air bag and got between 2-4ohms, I ordered a pack of 2 ohm 1/2 watt resisters. http://www.vetco.net/catalog/product...0rlda8c47ahdp5 and put the resister between the 2 wires to the airbag (across the pos/neg) it was not enough it still read as a open circuit so I put 2 resisters in series and that worked. Now I wanted to keep cruise but with my transmission the way it is (with cruise on the rpms are 400rpm higher for the same speed as holding the pedal) I dont use it anyway, I may at some point make find a solution to add it. Last edited by 92 SVX; 04-05-2013 at 10:08 PM. Reason: Added a pic of the wheel installed |
Re: Momo NonAirBag Steering wheel Install
Interesting... What year WRX/STi does your adapter work with? I'm mostly curious if an OEM steering wheel would fit the SVX, because that in turn means that this guy would fit:
This is the listing that says its compatible but I would expect more.
The splined shaft is likely the same for all subaru's as far as that wheel fiitting there is a how to for putting 08+ sti wheel in older wrx's and legacy's so those would work to put it into the svx. I thought about going that way but the sti wheel/adapter were going for high prices and most did not include the air bag. This part is compatible with 41 vehicle(s). Notes Year Make Model Trim Engine 2011 Subaru Impreza WRX Sedan 4-Door All 2010 Subaru Impreza All All 2010 Subaru Impreza WRX Limited Sedan 4-Door 2.5L 2458CC H4 GAS DOHC Turbocharged 2010 Subaru Impreza WRX Premium Sedan 4-Door 2.5L 2458CC H4 GAS DOHC Turbocharged 2010 Subaru Impreza WRX Sedan 4-Door All 2010 Subaru Impreza WRX STI Wagon 4-Door 2.5L 2458CC H4 GAS DOHC Turbocharged 2010 Subaru Impreza WRX Wagon 4-Door All 2009 Subaru Impreza All All 2009 Subaru Impreza WRX Premium Sedan 4-Door 2.5L 2458CC H4 GAS DOHC Turbocharged 2009 Subaru Impreza WRX Sedan 4-Door All 2009 Subaru Impreza WRX STI Wagon 4-Door 2.5L 2458CC H4 GAS DOHC Turbocharged 2009 Subaru Impreza WRX Wagon 4-Door All 2008 Subaru Impreza All All 2008 Subaru Impreza WRX Sedan 4-Door All 2008 Subaru Impreza WRX STI Wagon 4-Door 2.5L 2458CC H4 GAS DOHC Turbocharged 2008 Subaru Impreza WRX Wagon 4-Door All 2007 Subaru Impreza All All 2007 Subaru Impreza WRX Limited Sedan 4-Door 2.5L 2458CC H4 GAS DOHC Turbocharged 2007 Subaru Impreza WRX Sedan 4-Door All 2007 Subaru Impreza WRX STI Limited Sedan 4-Door 2.5L 2458CC H4 GAS DOHC Turbocharged |
The sti steering wheels fit the Svx with no problems at all, just unbolt one and bolt on the other
92 pearl SVX about to revive 92 Black 4ws (Jap spec) SVX 93 black SVX 93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear 95 bright red SVX 96 emerald pearl SVX about to revive |
Thanks for posting this up! What's the model/serial number for the steering wheel?
Thanks. Bill
This is what the listing says.
D35, KBA 70116. It was made in Italy in 12-97 it is identical (except for the horn button) to a wheel I purchased for my wife's car last year which was made in 2007 I believe. |
