SVX strut replacement (non - KONI)
Has anyone purchased and installed aftermarket rear struts from another Subaru Model/year into the SVX successfully?
I don't want to purchase OEM struts from the dealer... for all the obvious reasons/warnings here. And I don't want to purchase Koni inserts because they are too pricey. Surely someone has cross referenced other subaru models and found a strut replacement that bolts up and provides adequate suspension support. I'm thinking the Outback wagon would be a good candidate if the specs are close. I realize that the specs of an Outback strut vs. an SVX strut may be somewhat different, but how drastic can the difference be? I'm thinking as long as the strut has enough travel in each direction, has the same bolt pattern (strut to Spindle), same coil seat offset (where the coil springs sits), and same thread pitch (top of strut) I should be o.k....right? Would prefer to here from those with experience rather that just opinions, but begars can't be choosers, right?! Fire away... |
Re: SVX strut replacement (non - KONI)
Won't work, without massive work. I'm running WRX coilovers on my car and it took me about 13 hours to install them. The SVX suspension is unique in it's top mount bolt pattern and the thickness of the lower mount, although the overall strut lengths are similar-ish.
WRX front struts will work on the rear easy enough provided you are willing to grind down the rear hub enough for the strut mout bracket to fit. You would need an SVX top hat and would need to come up with the proper spacer for the threaded portion of the dampener. Of course I wouldn't know how the loss of the 1/4 inch of steel will do long term with the weight of the SVX. I would suspect the STi front strut might be a better fit as I think it has the same rear hub mount dimension as the SVX but have never seen one so I can't say for sure. Took us about 2-3 hours to swap to the Imp fronts on the rear on the racer but we didn't have a rear shelf to remove. It worked good enough I guess but no idea how it would work with a standard spring set up. Fronts are a little more dicey as you have the sway bar mount to deal with and welding a bracket on there with oil in the strut isn't the easiest thing to do without an incident.
Hi, I replaced all 4 with new OEM struts from subaruparts.com about 5 years ago. No trouble since then.
Kind Regards Marcus |
How much for the parts and then labor? Curious...
1994 subaru svx le 112k |
thank you benebob
The WRX front struts while close have 1" less travel and are approximately 3/4" shorter than the stock SVX rear strut. I've gone through the entire Monroe Sensa Track Strut inventory and have found only a couple comparable struts. I have a set of 91 Legacy struts on order as they match the SVX as close as possible in terms of lengths and travel.
The hardest part is finding a strut that has the same lower spring seat (perch) orientation. Many are not oriented in the same manner as the SVX and it is almost impossible to tell from a picture. Also, the perch could be welded onto the strut almost anywhere, also making it difficult to size up from a pic. I'll let you guys know how the 91 Legacy struts look once they come in. If the perch is correct, I assume it will raise the rear about 3/4", which is perfectly fine with me. Keep you posted... SVX rear strut specs & other comparables, in inches.... Year/Model - Body Length - Compressed length - Extended Length - Travel 92-97 SVX .... 15.25 ............. 15.25 ..................... 23 ........................ 7.625 02' WRX ........ 14.48 ............ 14.98 ...................... 21.43 ................... 6.45 91 Legacy L ... 16.50 ............ 14.125 .................... 22.25 ................... 8.125 Last edited by svxcuseme; 02-01-2011 at 02:04 PM. |
I donīt recall the price, but I ordered from subaruparts.com.
How much they charge for labor I cannot tell either, since I replaced them by my own. Itīs pretty straight forward, if you follow the manual. It is recommended to replace the self fastening nuts with new ones. They are pricy and you need plenty of them. In consequence I replaced the most importand ones on the front but did use lock tight on the rear axis instead. You might want to replace the rubber boots on front and rear axis (I didnīt do so and had to regret it) while you are at it. Kind Regards Marcus |
