VSS2 Harness Wanted
I am looking to buy a harness to the vehicle speed sensor 2. It is for a 1995 SVX L AWD. The wires broke off at a very crucial point of the harness and its nearly impossible to solder them back together. This is what I am looking for ----> IMAG0146.jpg
Thanks
Sam Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners My Locker |
Re: VSS2 Harness Wanted
Worst case scenario you can push the pins out of the connector, remove the old wires, and solder new wires on to extend to a place where you can more easily fix things. A paper clip will usually do the trick, but failing that, a large sewing needle will work to unhook the little clips on the pins.
I think I have a few with about 6-12" of wiring from ones I yank from the pick n pulls. I'll have to check.
Yes, I failed to check...woops. sorry!
