Old 05-24-2015, 11:15 AM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
Plans for the new SVX
As Old Tom said "And so it begins......."
Mortgage is paid off end of December, so will have a little spending money to put into the new car. Goal is a high performance daily driver that my wife can also drive, so keeping the automatic. Many of the mods below were validated on my Emerald Pearl, now in the possession of SuperCarnitas, that Young Tom was so instrumental in creating.
Phase 1
* Rota Boost 17 x 8 flat black with red lip
* Michelin Pilot Super Sport 245/40-17
Phase 2
* Brake redo
- Stainless steel brake lines
- Frozen rotors slotted rotors
- Axxis Ulta ceramic pads front; Axxis Metal Masters rear (Ulta not available for rear)
- ATE Super blue fluid
- Speed bleeder valves
- Red finished calipers
Phase 3
* Phenolic spacers
* AMR Engineering coil-overs with their “street” top-mounts; 350 lb/in fr, 250 lb/in rear (removable adjusting valve)
* Urethane sway-bar bushings
* $5, 15 minute rear subframe mod
Phase 4
* Subiechip performance chip with Nissan z32 MAF and Nissan Skyline z32 injectors
* Header back high flow exhaust system
* Cold-air intake maybe with the custom Tomyx “snorkus”, if I can get someone to weld it up.
Any suggestions?
Old 05-26-2015, 02:28 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Re: Plans for the new SVX
Any plans for 4.44 swap or will you be keeping the stock gearing?
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 05-26-2015, 02:43 PM
Don't know. Haven't thought about it. Pretty big ticket item. Not sure about the benefits. What Subaru models have the 4.44?
Old 05-27-2015, 12:19 PM
Tim's Avatar
Tim Tim is offline
4.44's are in the 97-99 (phase 1 transmissions, non-vtd, and correct me if I'm wrong on the years) 2.5 liter motors from the legacy, outback and forester. You do lose out on the high gearing for cruising (3000 rpm at 70 mph) but gain more low end grunt and reliability.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 05-27-2015, 12:32 PM
Phase 1
Phase 2
* Brake redo
Phase 3
* Phenolic spacers
Phase 4
Any suggestions?
Nice list!
Dont forget an ECUTune valve body.
I believe that Young Tom would weld one up for you if you asked him to.
Old 05-27-2015, 04:03 PM
You should buy LANs performance transmission. It is still for sale on eBay.
Old 06-09-2015, 10:13 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
I did the 4.44 conversion on my son's car and I definitely think it is well worth it, both in performance and durability. You do not notice much difference in cruising with the higher rpms. Throttle response is soooooo much better and off line power is very noticeable. AND, if anything, he gets better gas as the engine does not work as hard at cruising speeds. If you plan to keep the car for a lifetime like I am---used Legacy transmissions (4.44) are far more plentiful than SVX trans.
I might do the conversion on my runners if either has a trans problems. BUT, then again I have a parts car with only 2792 miles on the transmission AND engine.
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 06-09-2015, 02:50 PM
EdWindows's Avatar
5spd + coilovers = win :D
Is there actually any proven benefit to running the stage2, Z32 MAF, and 370cc injectors over stock with stage 1? From what I've read over the years stage 2 doesn't make any gains over stage 1 on stock motors.
Old 06-09-2015, 05:46 PM
I installed the Stage 1 on my Pearlie and Christine.
And was very satisfied with them.
I have the Stage 2 on two of my SVXi.
And am pleased with them as well.
The supercharged car and The Racer.
They both have headers and a very free flowing exhaust system.
The Racer has all four of LAN's cams, (the big ones) and a 5 speed.
SC car has 4.44s and porting.
They both have phenolic spacers.
If you go with the Stage 2 it gives you the ability to do more,
like your phenolic spacers.
If you go to a true cold air intake, cams, free flowing exhaust then we know that the Stage 2 upgrade has you covered.
I will defer to LAN, as he has logged much more data.
Old 06-21-2015, 09:32 AM
longassname's Avatar
Just some dude.
Significant Technical Input
The tuning on the ECUtune Stage1av1 and Stage2av1 were identical; however some testing was done by somebody else with your question in mind that indicated there might be some benefit to stepping up to the higher capacity air flow meter even on a stock car. I don't remember who it was or what the thread title was but he posted his information somewhere on these forums. He was logging the mass air flow meter readings and found the readings on the stock air flow meter got a little unstable at full load.
Nobody has ever done back to back testing of the same car on the same dyno on the same day to prove any performance difference since that would require changing fuel injectors and air flow meters on the dyno.
I always recommended sticking with stage 1 since the total cost was much less.
With the Subiechips chips the price is the same for the chip no matter which injectors or mass air meter but the cost of the injectors and air flow meter are still the major driving factor in the total cost.
