hydraulic vs solid lifters?
So im not very familiar with top end workings, and have a very base knowledge on cams and cam profiles. so my question is this one: our cars come with hydroulic (sp?) lifters, but everyone seems to convert to solid lifters, or suggest the conversions. on an na build, why is this recommended? Running 10-40 oil, and possibly different(if availiable) valve springs wouldnt be as reliable?
any info (in depth even, i catch on quickly, and if im stuck the internet is a good place to have) would be appreciated. my car died again, this time with massive over heating (melted my ign. coils!) and found fresh coolant in my fresh oil after i replaced my radiator. likely warped heads. so this time, im doing a full rebuild, but trying not to break the bank, parts stores dont exactly pay well... |
Re: hydroulic vs solid lifters?
wait, any weight of oil resists compression just the same, right?
There have only a few people to convert to solid lifters.
It is a very expensive upgrade. Unless you are running a much higher redline that 7200.
www.svxfiles.com The first SuperCharged SVX, the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway Fiberglass Hood thread My locker 4.44 Swap link Last edited by svxfiles; 08-10-2010 at 10:24 PM. |
whats much higher? ive seen it would be quite the expensive upgrade sadly.
What transmission do you have in your SVX?
right now, the stock one. when that motor gets done, itll be a jdm ra trans. i need to replace 2nd gear though.
